Thread: Hall effect proximity sensors
22-06-2019 #11
22-06-2019 #12
Series for NO, so the circuit only closes when both close.
Parallel for NC, so the circuit only opens when both open.
:D
I'm planning this with my Chester Mill CNC conversion, I've become accustomed to being able to shut down my X7 and know there will be no positional errors when I turn it on the next day, select the WCS and slot a part into a fixture, I can't imagine going back to having to indicate every time I fire a machine up, I don't think a homing system which requires you to re-indicate a fixture which hasn't been moved is acceptable, in fact I think that's the definition of Useless.You think that's too expensive? You're not a Model Engineer are you? :D
23-06-2019 #13
23-06-2019 #14
Why not have 1 NC and 1 NO, then it wouldn't matter whether you wire in series or parallel
It took some time for me to understand the second part of the reply as I don't get what part the Wildlife Conservation Society play in CNC. If I am cutting a few parts and have to turn off the machine then I zeroise the Z and 'Ref All Home' to send the X and Y back to the zero point. That way, when I switch on the next day, I know here the machine is.
BTW, I love these things, Engineers Lego......
https://www.arceurotrade.co.uk/Catal...-Metric-Blocks
Cheers,
Rob
23-06-2019 #15
23-06-2019 #16
23-06-2019 #17
Hi Nick,
WCS - I looked it up on Google. I actually rejected the idea that it could be the wildlife thing, toyed with Workflow Control System, Warehousing Computer Systems and World Coordinate Systems (Getting close there - that was defined as something to do with CNC). I did not think that with this latter CNC TLA you needed to know the precise latitude and longitude to define the machines X,Y 0,0, but apparently there it is. Even more incomprehensible is the UCS (universal Coordinate System, which even takes into account the Space/Time Continuum.
Maybe it is time that we had some TLA control, such as an Acronym Registration System (ARS). Maybe I could become an Acronym Registration System Executive (ARSE), although a lot of people probably think I already am.
Rob-T
24-06-2019 #18
An Acronym is a set of letters pronounced as a word, if the individual letters are voiced as in VCR or TLA it is an Initialism thus, somewhat amusingly, TLA is not a TLA :D
24-06-2019 #19
To get back on topic....
I do not use work offsets very often, which I presume depends on the accuracy of determining machine zero by homing all axes (axises ?). Most of what I do is one-offs and for that I zeroise locally when the piece is bolted down. If I have to do two or more, then I use a simple jig and, as I said before, leave the machine in a known position if I have to switch off and return to it next day.
It would be interesting to determine the increased accuracy with a dual sensor set. I would guess that it would not be significant for most home built machines.
What do the big boys, like HAAS, do?
24-06-2019 #20
choosing proximity sensors?
By the great waldo in forum Machine DiscussionReplies: 9Last Post: 03-04-2019, 09:55 AM -
Homing with proximity sensors
By routerdriver in forum General ElectronicsReplies: 4Last Post: 19-12-2017, 06:32 PM -
Help with proximity sensors
By D-man in forum General ElectronicsReplies: 18Last Post: 14-04-2016, 11:36 PM -
FOR SALE: Inductive proximity sensors
By Web Goblin in forum Items For SaleReplies: 0Last Post: 26-01-2016, 06:05 PM -
FOR SALE: Proximity sensors
By Web Goblin in forum Items For SaleReplies: 5Last Post: 13-09-2014, 08:02 AM
