    An Acronym is a set of letters pronounced as a word, if the individual letters are voiced as in VCR or TLA it is an Initialism thus, somewhat amusingly, TLA is not a TLA :D
    To get back on topic....
    I do not use work offsets very often, which I presume depends on the accuracy of determining machine zero by homing all axes (axises ?). Most of what I do is one-offs and for that I zeroise locally when the piece is bolted down. If I have to do two or more, then I use a simple jig and, as I said before, leave the machine in a known position if I have to switch off and return to it next day.
    It would be interesting to determine the increased accuracy with a dual sensor set. I would guess that it would not be significant for most home built machines.
    What do the big boys, like HAAS, do?
    an acronym is a set of letters pronounced as a word, if the individual letters are voiced as in vcr or tla it is an initialism thus, somewhat amusingly, tla is not a tla :d
    this forum is changing case - wtf !!!
    Hey, if you don't need it or want it don't do it! :D
    With decent screws and nuts I think a repeatability of 5 microns isn't out of reach, or even difficult, that's where I'm aiming with my next build, machining accuracy is likely to be closer to 15 but if you aim low you're bound to achieve shite results! :D
    I work to an accuracy measured in Angstroms +/- a foot.
    This is good enough for me, it is only woodwork
    I’ve just skim read this thread (funny in places !) so my answer to the first question which I think was essentially can I use Hall effect sensors instead of proximity sensors for homing -
    They require a magnet to get close to the target to trigger and so like all magnets in the workshop will grow metal hairs and become unreliable. I have one to play with on my new E-kart foot throttle. Great if the magnet and sensor can be sealed in a box but I think one part must ride on the gantry for CNC machines if they are the sole sensor so they can’t be protected.
    However for the auxiliary use as discussed they can be enclosed on the end of the stepper shaft at the rear of the motor or off the ballscrew and be sealed off. (Like the twist throttle of an electric bike).
    By Jingo, the man has a point !
    So use a micro-switch for the linear sensor and an optical for the rotary! :D
  1. choosing proximity sensors?
    By the great waldo in forum Machine Discussion
    Last Post: 03-04-2019, 09:55 AM
  2. Homing with proximity sensors
    By routerdriver in forum General Electronics
    Last Post: 19-12-2017, 06:32 PM
  3. Help with proximity sensors
    By D-man in forum General Electronics
    Last Post: 14-04-2016, 11:36 PM
  4. FOR SALE: Inductive proximity sensors
    Last Post: 26-01-2016, 06:05 PM
  5. FOR SALE: Proximity sensors
    Last Post: 13-09-2014, 08:02 AM
