  1. #6
    Quote Originally Posted by DaveZ View Post
    Hi Andy
    Can I experiment with each pin on the shield connecting to the stepper drivers.? To find which is which. (without blowing board up) I presume pin out diagram relates to shield. I've looked everywhere for one.
    Shouldn't need to experiment - everything should be relatively simple. I've drawn a basic diagram to give you an idea. Note that the colours of the wires mean nothing in my drawing, its just whatever colour I picked in paint.
    • First - be careful about the power supply + and - to the driver. Make sure you get them the right way around, else bye bye driver.
    • Second, Identify the pairs of wires from the stepper. It has four wires in two pairs. Use a multimeter in continuity mode to determine which wires are connected.
    • Connect one pair of the motor wires to A+ and A- on the stepper driver. The other to B+ and B-.
    • Next, connect DIR+ on the driver to X DIR on the shield
    • Repeat for PUL/STEP + to STEP + on the CNC Shield
    • Connect ENA+ to ENABLE or EN on the CNC Shield
    • Connect ENA-, PUL/STEP- and DIR- to Gnd on the CNC Shield
    • TEST!
    Note there is no power supply connection to the CNC Shield - this is intentional. I'm expecting the CNC shield to be powered by the arduino power or USB.
Name:	stepper wiring.jpg
  2. The Following 3 Users Say Thank You to AndyUK For This Useful Post:
  1. Arduino CNC Shield Power Routing
    By AcrimoniousMirth in forum Control Hardware & Systems
    Last Post: 03-07-2017, 07:37 AM
  2. eBay Nema23 Stepper mounts
    By Slixxor in forum Gantry/Router Machines & Building
    Last Post: 05-06-2016, 05:02 PM
  3. Replies: 0
    Last Post: 22-06-2014, 01:59 PM
  4. RFQ: RFQ Nema23 stepper mount
    By r0bsk1 in forum Projects, Jobs & Requests
    Last Post: 15-02-2014, 02:16 PM
  5. WANTED: stepper driver module
    By tinshak in forum Items Wanted
    Last Post: 16-01-2013, 09:31 AM
