Hey so are the EN/Ground shared between all drivers ? in like parallel ?
Just wondering i just saw this looking to do the same thing for my cnc hard to find wiring for external drivers on the shield
Shouldn't need to experiment - everything should be relatively simple. I've drawn a basic diagram to give you an idea. Note that the colours of the wires mean nothing in my drawing, its just whatever colour I picked in paint.
  • First - be careful about the power supply + and - to the driver. Make sure you get them the right way around, else bye bye driver.
  • Second, Identify the pairs of wires from the stepper. It has four wires in two pairs. Use a multimeter in continuity mode to determine which wires are connected.
  • Connect one pair of the motor wires to A+ and A- on the stepper driver. The other to B+ and B-.
  • Next, connect DIR+ on the driver to X DIR on the shield
  • Repeat for PUL/STEP + to STEP + on the CNC Shield
  • Connect ENA+ to ENABLE or EN on the CNC Shield
  • Connect ENA-, PUL/STEP- and DIR- to Gnd on the CNC Shield
  • TEST!
Note there is no power supply connection to the CNC Shield - this is intentional. I'm expecting the CNC shield to be powered by the arduino power or USB.
Name:	stepper wiring.jpg
