Thread: Opto isolator question
29-06-2019 #2
29-06-2019 #3
29-06-2019 #4
I have had a quick look at the various arduino boards available
this looks like a ready made you can use (amazon are out of stock but it appears to on sale from ebay )
https://www.amazon.co.uk/d/Wall-Sock...ino/B01MRQFYJN
hi res readable picture from amazon advert
the small 16 pin IC is a quad opto isolator - part number PS2801-4
another possible board
https://ja.aliexpress.com/item/32748...3-954e0244d34d
I was going to say the problem with all of the chinese boards is the lack of information but
I have found this
http://www.ekt2.com/pdf/412_ARDUINO_...FET_SWITCH.pdf
johnLast edited by john swift; 29-06-2019 at 06:34 PM.
30-06-2019 #5
Cheers guys, I really appreciate the help. I went ahead and used my mosfets and soldered it up in the sun yesterday...boy it was hot!!
Anyway...its all sorted now although the red switches are very bright
Cheers again...my machine will hopefully be finished this year!
Sent from my SM-G920F using Tapatalk
30-06-2019 #6
Gerry
the relay board is a simple alternative to using transistors that some will prefer
( as always the best solution is the one that works for you )
the relay board has the advantage the outputs can be wired to either have a common +24V or common 0V / ground connection
Charlie
great result
do you have the option to use 28V bulbs in the switches ?
under run 28V bulbs will last longer
an alternative would be to add a resistor in series with the bulb
if the bulb takes 40 mA a 100 ohm resistor would drop the voltage by 4 V
john
30-06-2019 #7
Opto isolated Bob and drivers causing a strange fault.
By lucan07 in forum General ElectronicsReplies: 2Last Post: 02-05-2016, 09:28 PM -
NEW MEMBER: Re my question
By oldwoodworker in forum New Member IntroductionsReplies: 32Last Post: 20-09-2013, 09:07 PM -
To usb,or not to usb,that is the question.
By Jumbo in forum General DiscussionReplies: 11Last Post: 17-10-2011, 09:21 PM -
question ...
By Wobblybootie in forum General DiscussionReplies: 6Last Post: 04-01-2010, 12:04 AM -
3 axis opto for £75
By irving2008 in forum Motor Drivers & ControllersReplies: 4Last Post: 02-07-2009, 11:44 PM
