    Quote Originally Posted by john swift View Post
    looking at the photo of the opto-isolator board
    it has 3K resistors fitted as shown on the chinese circuit diagram
    so the output current is even more limited
    with a 3K or 3.3K resistor between the gate and source of the Fets you have you could wire the opto-isolator to pull the gate upto +12V (half of the 24V supply ) to switch the FET on
Name:	opto-isolator with FET lamp driver.jpg
    the BOB is like this I have looked at before
Name:	CNC BOB  .jpg
    John
    Cheers John, look what I just found... seems I may as well use them as I have them lying around
    Sent from my SM-G920F using Tapatalk
    it looks like you have all the parts to try it out with the FET
    the combination of the high value resistors and the gate source capacitance is going to slow the FETs switching but for this application it should be OK
    I usually use a 100 ohm resistor to connect the gate to a low impeadance driver
    (very like the 100 ohm "grid stopper" with valve (tube) circuits )
    John
  1. Opto isolated Bob and drivers causing a strange fault.
    By lucan07 in forum General Electronics
    Last Post: 02-05-2016, 09:28 PM
  2. NEW MEMBER: Re my question
    By oldwoodworker in forum New Member Introductions
    Last Post: 20-09-2013, 09:07 PM
  3. To usb,or not to usb,that is the question.
    By Jumbo in forum General Discussion
    Last Post: 17-10-2011, 09:21 PM
  4. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
  5. 3 axis opto for £75
    By irving2008 in forum Motor Drivers & Controllers
    Last Post: 02-07-2009, 11:44 PM
