Thread: Opto isolator question
29-06-2019 #18
Optically Isolated means the input has no current flow or connection to the output, a lot like a Relay!
By using one wire on the output you are connecting your wires to a floating point in your circuit!
The outputs will not work unless both connections are used, you need a common ground or common live to one side of each output in order for there to be any signal at the other side of the output! :DYou think that's too expensive? You're not a Model Engineer are you? :D
Opto isolated Bob and drivers causing a strange fault.
By lucan07 in forum General ElectronicsReplies: 2Last Post: 02-05-2016, 09:28 PM -
NEW MEMBER: Re my question
By oldwoodworker in forum New Member IntroductionsReplies: 32Last Post: 20-09-2013, 09:07 PM -
To usb,or not to usb,that is the question.
By Jumbo in forum General DiscussionReplies: 11Last Post: 17-10-2011, 09:21 PM -
question ...
By Wobblybootie in forum General DiscussionReplies: 6Last Post: 04-01-2010, 12:04 AM -
3 axis opto for £75
By irving2008 in forum Motor Drivers & ControllersReplies: 4Last Post: 02-07-2009, 11:44 PM
