Thread: Opto isolator question
Gerry
the relay board is a simple alternative to using transistors that some will prefer
( as always the best solution is the one that works for you )
the relay board has the advantage the outputs can be wired to either have a common +24V or common 0V / ground connection
Charlie
great result
do you have the option to use 28V bulbs in the switches ?
under run 28V bulbs will last longer
an alternative would be to add a resistor in series with the bulb
if the bulb takes 40 mA a 100 ohm resistor would drop the voltage by 4 V
john
30-06-2019 #2
Opto isolated Bob and drivers causing a strange fault.
By lucan07 in forum General ElectronicsReplies: 2Last Post: 02-05-2016, 09:28 PM -
NEW MEMBER: Re my question
By oldwoodworker in forum New Member IntroductionsReplies: 32Last Post: 20-09-2013, 09:07 PM -
To usb,or not to usb,that is the question.
By Jumbo in forum General DiscussionReplies: 11Last Post: 17-10-2011, 09:21 PM -
question ...
By Wobblybootie in forum General DiscussionReplies: 6Last Post: 04-01-2010, 12:04 AM -
3 axis opto for £75
By irving2008 in forum Motor Drivers & ControllersReplies: 4Last Post: 02-07-2009, 11:44 PM
