  1. Good point, but if the charge pump is stopping the motion, the red light on the driver will be on.
    The charge pump is connected to the enable of the driver and if you get a positive signal on the enable you will get no torque on the shaft and the red light goes on.
    Quote Originally Posted by tribbles View Post
    I think Gary wants you to manually control the step lines to see if, when you connect it to +5V, the motor tries to move, or whether it doesn't move.
    The controller you've got looks like it has the pump charge circuit on it - this means the computer must provide a constantly varying signal on the STROBE pin (pin 1) of the parallel port. This can normally only be done if you are running CNC software that is capable of driving it - and you've enabled it in the software.
    However, having said that, it may only just drive the enable output on the parallel port interface (which would then be connected to your drivers).
    The pump charge tries to prevent the motors from being moved during startup/shutdown of the computer. Manually wiggling the clock line will definitely override it.
    thank you for
    Gary - audioandy - Tribbles
    Finally I turned the engine problem is my parallel cable
    Now I'm starting a production of my 1rst cnc machine
    [email protected]
  3. Good, happy cutting.
    thank you very much
    [email protected]
  1. Replies: 1
  2. Stepper motor help.
    By Kammo1 in forum Stepper & Servo Motors
    Last Post: 12-02-2010, 11:11 AM
  3. Stepper motor help
    By Mucky Mike in forum Stepper & Servo Motors
    Last Post: 04-04-2009, 04:25 AM
