  1. #6
    Lives in Plymouth, United Kingdom. Last Activity: 7 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Good point well made, but the argument still stands.
    Another point - the drivers typically have their own onboard rectifiers (they are DC-driven devices even with a AC supply), if you look at the physical size of the drivers vs a PSU supply capacitor then you can expect that there is a compromise with the onboard rectification (that needs to be balanced against the losses introduced by the additional rectifier). But, yes, you can still opt to use the AC supply straight from the toroidal. In that case I'd chose to wire each driver straight back to the transformer, and not to daisy-chain them.
    It's certainly true that onboard capacitors are probably smaller than those that someone building their own PSU would use. However, we are talking stepper drivers here, not audio amplifiers, and a bit of PSU mains frequency ripple really makes no practical difference. I've measured around 10V ripple on my own PSU with the machine running a test toolpath and it really doesn't seem to worry. Maybe you'll lose a tiny bit of the torque theoretically available, but that's about all. The stepper driver itself is chopping the motor output current at a much higher frequency, and it will adjust dynamically to whatever the input voltage happens to be. After all, even with the ripple, the supply voltage still stays within the nominal working range.
    As Doddy says, though, try not to daisy-chain them and wire each driver back to the transformer independently. That makes sure that any voltage drop in the wires to one driver does not affect the others.
  1. Help me choose my first spindle
    By Desertboy in forum Spindles & Drive Motors
    Last Post: 04-05-2018, 10:49 AM
  2. Help needed to choose a machine.
    By DustySixString in forum Machine Discussion
    Last Post: 28-07-2017, 04:47 PM
  3. Help me choose a mill.
    By Fingerpuk in forum Milling Machines, Builds & Conversions
    Last Post: 25-11-2016, 12:41 AM
  4. HELP:How to choose
    By sinograver in forum Milling Machines, Builds & Conversions
    Last Post: 17-10-2011, 02:00 AM
  5. How to choose a lead scew
    By GTJim in forum Lead Screws, Nuts & Supports
    Last Post: 15-02-2009, 12:30 PM
