    Hello people.
    Finally started rebuilding my laser bit by bit, after getting fed up with sellers warranty fix promises.
    Today is X axis stepper/driver's turn, as rebuilding X axis.
    I'm having moving resonance issues in toolpath. Someone suggested to run a project and keep hand on the head as its moving (dont worry, laser tube was off :D ). I noticed pretty strong vibration in X direction while accellerating/decellerating and on constant low speed (10-30mms).
    Before i had been advised to swap over drivers to see if other problem goes away or moves to other axis (X overheating with a lot of small acc/dec movement). It didnt. Drivers function.
    Question is are they functioning correctly ? Or is the motor flaky ? Do stepper motors go flaky ? Not outright dead but weird, ghosts'n'stuff?
    As for drive spec - no clue. M415DRV. Unidentifiable. Current set to 0.57A RMS. Stepping X32.
    Motor is 17HA705Y-1A, FH171215 Smooth, 34mm nema17. Again, unidentifiable.
    Any way to diagnose this without outright replacing motor and driver ? (which i dont have spares of).
    #Edit# P.S. I cant seem to disconnect the "connector" on the motor. Is it just a piece of plastic and wires are just there ?
ID:	25987   Click image for larger version.
ID:	25988   Click image for larger version.
  1. Replies: 2
    Last Post: 06-02-2019, 08:36 PM
  2. How to convert variable speed brushed DC motor on old lathe
    By paulus.v in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 06-11-2015, 11:34 PM
  3. Replies: 1
  4. M542 driver - motor vibration at low speeds
    By birchy in forum Motor Drivers & Controllers
    Last Post: 22-11-2013, 08:16 PM
  5. motor mount vibration vs torque'd bolts
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 22-10-2013, 10:36 AM
