28-06-2019 #1
Hi guys i set up my vfd to using the pedometer with my spindle as fault testing them and found the spindle would make the sound of it speeding up but the actual spindle was not turning.
i have read another thread that had same issues as this but it was down to loose connections which i have checked as well.
I also noticed when i turned it off to check connections that it became very warm very quickly.
i have checked each wire and all 3 are connected properly pins 1,2 and 3 are live and 4 is the ground pin which i have not set up yet on the spindle.
Any thoughts on this?
29-06-2019 #2
Not an expert on this but have you seen this sticky thread for the parameter set up - assuming this is a huangyang VFD? Sounds like something is not right in the VFD config?
http://www.mycncuk.com/threads/5814-...nd-Advice-More
29-06-2019 #4
I have only been able to find the A100 module or the E100 module manual for the Nowforever VFD's which are not exact, however I have been trawling through the internet and finally found the correct settings for my D100 VFD and it is Finally up and running.... only been 2 years since I brought it, I can now start learning the software side and start a project.
motor making noise but not spinning
By dek667 in forum Spindles & Drive MotorsReplies: 0Last Post: 03-08-2018, 02:47 PM -
CNC 3040T-DJ Router spindle won't stop spinning
By Chilli in forum Chinese MachinesReplies: 5Last Post: 19-11-2016, 01:33 AM -
Problem with Spindle not spinning
By Noplace in forum Spindles & Drive MotorsReplies: 4Last Post: 22-01-2016, 02:40 PM -
CNC Project - Spinning Wheel Bobbins
By Washout in forum Woodworking Project ShowcaseReplies: 3Last Post: 14-07-2015, 09:25 PM -
Touch Probe
By luke11cnc in forum Probing, Digitizing & ScaningReplies: 28Last Post: 31-01-2012, 01:16 AM
