My thoughts would be to unplug both Y motors from the drivers (power off!) and do a simple check of the resistance through the pairs of windings in both motors. They should all be about the same, around a few ohms.
If you are de-rating one of the steppers on a dual stepper axis just go easy on the feeds to avoid stalling one out before the other (assuming they are just slaved in software)
01-08-2019 #2
Hi Neale, yeah all DIP switches are the same.
I may check the resistances in the future but once the current setting was lowered again the difference in temperature wasn’t anywhere near as bad - maybe 5-7degreesC.
I’m not sure I understand what you mean by de-rating one of the steppers? Both are set the same to half step and a lower current (I think this might be what you mean by de-rating?) to manage the heating. I spoke to Gary at Zapp who set me straight on matching/setting to the the Peak current on the motor driver to the current rating of the motor but still remain confused, especially when I’ve read Leadshines advice is to match/set to the RMS column.
I’ve run the motors fine by setting the motor drivers Peak current value to match the specified motor current for a few years but I’d hoped to better understand why it’s done this way.
All I can figure is that I can either have higher voltages for more torque at faster speeds, but I have to set a lower current (match the motor current to the Peak value on the driver) to manage the heating OR I can set the drivers to match the RMS value to the motors rating and have a lower voltage, again to manage the heating - I ‘suppose’ then I’d get higher lower speed torque, but lower top speeds/top-end torque due to the lower (thus slower) voltage changes?
I could do with a good reference text!
How-To: Feed Rate Calculation
By Lee Roberts in forum Machine DiscussionReplies: 20Last Post: 25-03-2020, 04:09 PM -
Harrison 280 steppers??
By lolosPL in forum Stepper & Servo MotorsReplies: 2Last Post: 11-03-2018, 09:52 PM -
O-ring calculation
By Clive S in forum General DiscussionReplies: 3Last Post: 18-03-2017, 04:54 PM -
To big steppers?
By JW1977 in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 05-02-2017, 10:00 PM -
pulse equivelant calculation
By yasser in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 17-05-2016, 10:10 AM
