  1. #31
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    I’d also caution to understand how much grief you’re prepared to put up with. I can go from print to board with the usual uv processes within an hour and that includes 10 thoa routing and 0.5mm pitch SSOP devices with 80% success (and likely reworkable failures). The quality surpasses anything I’ve milled myself. You experience may vary, of course
  2. #32
    Doddy's Avatar
    Last post, I promise!
    Of course isolation routing opens the possibility of through hole plating... something else I promised myself to try.
    I really need to get back on the horse with this one.
  3. #33
    As far as cutters are concerned, I use a V cutter of 0.2 mm end diameter. I have ordered some 10deg ones from China, but so far they have sent me 30deg ones twice ! The narrower angle ones have better control of track width.
    For drills, I buy from circuit2u.co.uk £6.99 for a pack of 10. They are resharpened ones, but good and sharp. For normal components I use 0.8mm, but headers and connectors need a slightly bigger diameter, so 1mm. Actually, if the pads are large enough, I just drill the lot at 1mm.
    Doddy, I understand your frustration, I have one of those F-awful machines from Exeter. I have spent a lot of time aligning it, even to the extent of shimming the bed with layers of kitchen foil. It now gives acceptable results, but I am still not sure the spindle is at 90deg to the bed as a cut with a large cutter produces a very 'steppy' result. I think the rails are twisted relative to each other. This is because of the inaccuracy in manufacture.
    I used to use 0.2mm endmills, but those little feckers would break if you looked at them funny. Like the 'pingfuckit', I have a box of them with more on the floor.
    Happy Days,
    Rob
  1. BOB 3 Axis, optical isolation
    By thjremy in forum Electronic Project Building
    Last Post: 05-01-2014, 04:15 PM
  2. gerber to dxf for PCBs
    By Web Goblin in forum Computer Software
    Last Post: 26-10-2013, 08:25 PM
  3. NEW MEMBER: PCBs - desktop CNC - Hi from salisbury
    By Plod in forum New Member Introductions
    Last Post: 07-09-2013, 09:34 AM
  4. PCB Isolation Routing
    By Mad Professor in forum General Discussion
    Last Post: 16-03-2011, 09:46 PM
  5. PCB Isolation Routing
    By CHudson in forum Milling Machines, Builds & Conversions
    Last Post: 10-10-2010, 08:34 PM
