Page 2 of 2 FirstFirst 12
    Thanks, guys. I have just wired the AC to DC transformer bits together for the first time and connected it to the mains. I have not yet used a 'delay on' timer relay and just wired an NTC thermistor on the live between mains in and the primary winding. On first switch on nothing dramatic happened and I am getting 53 volts at the DC output which is close to what I wanted. I was surprised that the thermistor did not get hot like I thought they were supposed to. Could this be because there is no load on the DC output? Similarly the bridge rectifier does not seem hot or even warm. Is this normal? The thermistor is a SL15 2R507 that Airlink transformers recommend for toroidals up to 1kVA
    Regards ...Chris
    Quote Originally Posted by chillybo View Post
    Regards ...Chris
    Keep an eye on it under load, but there's many toroidal running with just NTCs - that's what they're designed for. If it works - you've saved yourself £40.
    (Mine has just an NTC on a 800VA transformer)
  3. The Following User Says Thank You to Doddy For This Useful Post:
  4. #13
    Just need to create a load for it now so I need to know what are the best stepper drivers for my set up. It will probably be better to start a new thread for this.
    Regards ...Chris
  5. #14
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 2 Hours Ago Has been a member for 8-9 years. Has a total post count of 490. Received thanks 81 times, giving thanks to others 27 times.
    The second one looks like a bit of a home project, TBH. The first (German) one looks pretty sensible, containing an NTC, timer relay and overtemp protection.
  6. The Following User Says Thank You to Muzzer For This Useful Post:
  7. #15
    In post 10 ,the second link for the
    "Soft-start, inrush current limiter for toroidal transformers-assembled, tested"
    reminded me of project 39 from Elliott Sound Products
    Soft-Start Circuit For Power Amps
    http://sound.whsites.net/project39.htm
    project list
    http://sound.whsites.net/p-list.htm
    John
  8. The Following User Says Thank You to john swift For This Useful Post:
  1. 500VA Toroidal Transformer 2x55Vac (RS0500P1-2-055)
    By Mad Professor in forum Classified Ads, Buy, Sell & Swap
    Last Post: 28-01-2018, 08:31 PM
  2. FOR SALE: PSU Rectifier + Capacitor smoothing board for toroidal transformer
    By Jonathan in forum Items For Sale
    Last Post: 02-02-2017, 10:47 PM
  3. Failed toroidal transformer
    By Neale in forum General Electronics
    Last Post: 05-01-2016, 11:45 PM
  4. Toroidal Transformer
    By Carlb1058 in forum General Electronics
    Last Post: 17-08-2013, 06:54 AM
  5. Toroidal transformer voltages - sanity check needed!
    By m_c in forum General Electronics
    Last Post: 03-10-2011, 08:34 PM
