01-08-2019 #3
Recently i learned that GT2 pulleys are tricky in my case.
I need to get a pulley that is 40teeth/10mm wide belt/8mm bore. And i cant, for the life of me, find one.
It is either gonna be 6mm wide belt or 5mm bore... Starting to pull my hair out (whats left of it anyway).
I dont know anyone with a small lathe to bore it out, no point going back to 6mm belts as machine is supposed to be fast (not a 3d printer, that crawl.).
Its a "pick 2" triangle situation. Gah.
Thanks for the drawing, btw, thats all i needed - an approximation.
Since shaft center runs about 35mm above "floor" i can stick in whatever doesnt exceed 55-60mm in diameter.
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Belt drive and pulley sizes
By j2sip in forum Belt Drive, Pulleys & TimingReplies: 22Last Post: 20-06-2010, 10:44 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
Standard Drive Belt Size ?
By Lee Roberts in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 19-05-2009, 10:56 AM -
Re: Standard Drive Belt Size ?
By HS93 in forum Belt Drive, Pulleys & TimingReplies: 0Last Post: 18-05-2009, 03:30 PM
