    These are the guys I get my pulleys from:
    https://www.beltingonline.com/40-too...h70ar358nm5ci3
    Maybe not the absolute cheapest but service and quality is spot on. If you need to calculate belt lengths etc. go here:
    http://www.hpcgears.com/n/left_menu/calc/calc.php
    What is AT5 pulley ? Are they GT2 with different naming convention ?
    Quote Originally Posted by threedee View Post
    Sorry I gave you a link I had stored - Beltingonline do a big range of different types of belt/pulleys and do give accurate dimensions and will bore to order so I thought they might be able to help. AT5 is a larger tooth pitch (5mm vs 2mm) than GT2 and I was advised that they're about the best for backlash at a sensible price. But with the larger tooth pitch, for the same number of teeth they'll be propotionately bigger diameter so you might have fit problems - and if the other pulley in the system is GT2 then you'd obviously have to change both.
  1. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  2. Belt drive and pulley sizes
    By j2sip in forum Belt Drive, Pulleys & Timing
    Last Post: 20-06-2010, 10:44 AM
  3. Stepper shaft size and pulley bore size problem
  4. Standard Drive Belt Size ?
    By Lee Roberts in forum Belt Drive, Pulleys & Timing
    Last Post: 19-05-2009, 10:56 AM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 03:30 PM
