    I am looking to start to put together my control box for my cnc, I have decided to with the DDCSV controller, which I will mount on the front on the enclosure, what I would like to know is, is it best to put the VFD inside or outside of the enclosure? If it should go inside the enclosure, where is the best place to mount it, I have read that it should be mounted at the bottom of the enclosure? Should it be kept away from any of the electrical components within the box? I am looking getting a metal enclosure, I do have an old pc case, but it won't be deep enough to mount the VFD. I do not have any electrical experience, just a little basic knowledge, so any help or advice would be very much appreciated. Thank you everyone
    You haven't said which VFD you have, but if it is anything like mine it has a digital display of speed and a manual speed control on the front, neither of which will be accessible if it's inside the box. More importantly you must ensure good air flow through the VFD to avoid overheating. Correct air management is critical for power electronics.
    Mine is on the wall behind one end of the machine near where the drag chain ends, partly because I can see it properly and set the speed and partly because I should have bought six metres of screened 4-core cable instead of five.
    Kit
    Kit
    Thank you for your reply, it is a Huanyang VFD, with a digital display and manual speed control, luckily I have plenty of cable, so can mount it pretty much anywhere within reason 😁
    It's got to be better having the VFD inside a steel cabinet from an EMC (electrical noise) POV, as well as making a neater installation. In both my machines, I have the VFDs mounted inside and have a fan to ensure they can stay cool. Rather than have the fan powered all the time, I have a simple central heating thermostat to turn it on when / if the air temperature exceeds a threshold which is something like 40C. There's an exit grille with a foam filter above the VFD and the fan is mounted near the bottom of the cabinet.
    Muzzer,
    Aren't you shutting one of the biggest sources of electrical noise inside the metal shielding meant to keep it out of the other electronics? However I can see the point of keeping all the noise from the stepper drivers and VFD contained and away from the controlling computer.
    Paul,
    Perhaps this is an opportunity to broaden the discussion to noise in general, it's sources, consequences and how to deal with it.
    My own controller is an old PC case with the PSUs and stepper drivers in it with the parallel breakout board in it's own metal box inside there as well (I use a cheap Chinese breakout and LinuxCNC). I left the PC PSU in there to provide 5v for the breakout and 12v for the fans.1uF capacitors are connected across all the inputs on the breakout board. Cables to/from the steppers, spindle and limit switches are screened with the screens only connected to ground at the controller or VFD end. It's been working OK for now.
    Your mains supply can spread noise and there are recommendations to feed the VFD from a socket as far away from everything else as possible. My entire machine, computer, dust extractor and all, is fed by one dual socket and still works so don't spend any money on getting new sockets installed at the other end of your shed unless you have to.
    Kit
    Inside an enclosure is good, check the manufacturer's requirements though as adequate cooling is essential.
    Unless your VFD is really shoddy the majority of EMI is carried through wiring, not the air, although proximity will mean short cable runs and may require a filter on each mains equipment input in the box and shielded cable from the VFD to the motor is advisable.
    Outside is fine though, I've run a benchtop CNC mill for about 7 years with the VFD mounted to a bracket on the spindle motor without any issues and my lathe VFD is mounted next to the DRO display with a tacho on top of the VFD, that's worked fine for 20 years or so :D
  1. can Nema 23's be placed inside box tubing X / Y axis
    By Hulksmash in forum General Discussion
    Last Post: 27-07-2018, 10:42 PM
  2. L gantry design with 2 aluminium beams bolted with T nuts inside...
    By pierantoine in forum Gantry/Router Machines & Building
    Last Post: 30-04-2017, 02:14 PM
  3. Need Help! Gerber System 48 Build Issues Video and Pictures Inside!
    By toby in forum Gantry/Router Machines & Building
    Last Post: 14-08-2016, 01:55 PM
  4. editing files inside solidworks
    By reefy86 in forum Solidworks
    Last Post: 17-02-2016, 12:20 AM
  5. Inside pics of a 3040 300w DC spindle motor
    By Musht in forum Spindles & Drive Motors
    Last Post: 13-09-2015, 07:23 PM
