Thread: Brummie, New Member Needs a Hand
[QUOTE=terry1956;109700]Hi Martin, confused .
Brummie is a nickname i inhereted from the Army.
I live in Blackwood Gwent, I purchased the 3D CNC Router,. I have Built it, but have not got a clue about anything.
As there are no instructions at all hence i will not try anything I have searched online but results only come back with 6040's.
21-07-2019 #2
Hi, the basics of cnc routers are the same, be it a 6040 or a far larger machine. You will of course no that you will need some sort of design cad software like fusion 360, which can also write the g code needed to send to the router control software like mach3. If you have build the machine, I take it you have mach3 already and have been able to move the spindle etc. Is that correct. I live in Yeovil, so some distance from you, but if you feel like a drive, I would be happy to help you out. Someone took time out to show me the ropes, so happy to do the same.
22-07-2019 #3
[QUOTE=terry1956;109710]Hi, the basics of cnc routers are the same,
Hi Terry appologies forthelate reply, Yes the programmes I do have is Mach3, I have Vectric Carve, and PhotoVCarve , The actual Machine I have is a 6090 CNCEST, 1500KW VFD,
As I said before I have built the machine, I obtained some spindle settings. I have tried to apply them and give up, On Mach3 I think I have tried to run one of the sample programmes but nothing happend what so ever, I have no CNC Knowledge only what I have seen on Youtube so in March this year i give up in frustration.
Brummie.
23-07-2019 #4
hi, ok, when you say nothing happens, can you move the spindle on the x,y,z axis using the jog movement. or are your ports and pins settings wrong, are you trying to use a 64bit pc, mach 3 will not work at all if you are.
23-07-2019 #5
[QUOTE=Brummie;109723]Heya Brummie, welcome to the forum.
Unfortunately you're being very vague about the problem. If you post more information we may be able to help. Try and answer the following:
- Pictures/Videos of the machine and the problem. Try to walk us through the process you're going through to get the machine to work, and the process you're going through to apply these settings.
- Basic machine information. Does it power up, does it move, how is it connected to the PC, wiring photos or better yet diagrams. At what stage does a problem occur?
- What are these settings you're trying to apply? Are they settings for the VFD itself, are they for the Mach3 software, or are they on VCarve?
23-07-2019 #6
[QUOTE=AndyUK;109725]Hi Thanks for your help guys, Im not being vague at all, all I have noted on here is the sum total of what I know. I have turned the machine on 2 times since i bought it last year. nothing at all happens, so I turned it off and covered it up. I know absolutley zilch, Hence asking if anyone lives in south wales so I can watch what they do. I have no instructions at all no wireing diagrammes, I bought a V carve programme and bought Mach3 programme and a stand alone PC. .
24-07-2019 #7
ok, check list.
check your pc is not using windows 64 bit, as this turns off the printer port and nothing will work. you will need to reformat c drive and install windows running 32 bit, or xp program.
if however you are not running windows 64 bit. then it looks like your ports and pins are not set up. to sort this we will need to know the name of the break out board you are using. at this stage we can’t go any further.
01-08-2019 #8
Thanks for the detailed answer. I have a 32bit PC with windows XP. I know how to switch on the spindle controler and there is a "Thud" from the table then nothing happens. so i turn it off get angry and throw spanners and screwdrivers about. I am useless at following instructions. I NEED to see some one operate one. further info it is a CNCEST 6090. with no istructions for build and what i have found out i have to set the spindle some how? Hopefully someone from south wales see this post.
24-07-2019 #9Brummie. First welcome to the forum. If you want help you need to supply the information that people ask for but you are not doing this so it make it difficult to help. Nobody has a crystal ball that works.Hi Thanks for your help guys, Im not being vague at all, all I have noted on here is the sum total of what I know. I have turned the machine on 2 times since i bought it last year. nothing at all happens, so I turned it off and covered it up. I know absolutley zilch, Hence asking if anyone lives in south wales so I can watch what they do. I have no instructions at all no wireing diagrammes, I bought a V carve programme and bought Mach3 programme and a stand alone PC. .
Try and answer the questions you have been asked. It will all come together in time and we all have to learn...Clive
25-07-2019 #10
[QUOTE=Clive S;109735]Brummie. First welcome to the forum. If you want help you need to supply the information that people ask for but you are not doing this so it make it difficult to help. Nobody has a crystal ball that works.
All I asked was If anyone Lives in the south wales Area of either Newport, Cardiff or Swansea.? and would they mind coming around to SHOW mewhat to do. I do not know what scemetic means? UnlessI am physically shown ill never get it. sorry to waste your time.
Looking for new hand controller/Pendant
By JOGARA in forum Machine DiscussionReplies: 24Last Post: 24-01-2020, 09:22 PM -
Hand Ergometer
By irving2008 in forum General DiscussionReplies: 50Last Post: 11-08-2013, 05:55 PM -
75 mm HAND WHEEL
By Lee Roberts in forum Programmers CornerReplies: 18Last Post: 19-03-2012, 02:58 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
NEW MEMBER: second hand machine
By steve r in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 09:00 PM
