Thread: eMachineShop Upgrade
07-04-2022 #121
Thank you very much!
SW received!
Regards
Amarillis
08-04-2022 #122
Well, seem like I'm stucked again...
So, here is my workflow...
I work with the last EMS version available that is 1.950 at the moment...
After everything is done, I save the work using the emsx file type...
I open the file emsx with a text editor and remove the line CREATOR....
I open the file with the 1.932/1.935 version of EMS and export the work using the DXF format...
BUT, I tried to open the DXF file with FREECAD and nothing shows...
So I tried to save the file in the STL format using the 1.932 ver...
At this point a popup shows telling me to upgrade to the latest version and no STL is produced...
Since I only need to 3D print my work I really don't know what to do...
Moreover, I still do not understand where to put the EMS.DAT file since there is no APPDATA folder for the 1.932 version without an install procedure...
Any help?
Regards
08-04-2022 #123
I'm no expert but I think that versions later than 1.935 save the file in a format that 1.932 and 1.935 can not read. I create all my drawings in 1.932. You might have to do the same but
I am sure someone with better knowledge will be along soon to give you better advice. Regards.
10-04-2022 #124
11-04-2022 #125
11-04-2022 #126
Well, thank you very much for your replay!
I really appreciate it!
And, by the way, maybe your are not an EXPERT but your knowledge is way deeper than mine...
So, with that said, your replay is a perfect recap of all the operations we should do to make a DXF or STL type of files using version 1.932/35...
Thank you again, I will give it a try in the next days...
Regards
Amarillis
25-04-2022 #127
Morning all
I am TOTALLY new to this! Im not a CAD guy....
I imported a DWG file and spent about 10 days learning the program, and editing the DWG drawing.
Much to my dismay .. when I finally got this right and wanted to save my drawing back to a DXF / DWG file..
I found out that I now need to purchase an upgrade..
FOR ME THIS WAS A 1 TIME DEAL..... I don't manufacture or anything, was just gonna have the drawing sent to an EVA foam manufacturer to cut the sheets with a 4 axis router..
I AM NOW STUCK BETWEEN A ROCK AND HARD PLACE...
Is anyone willing to let me email you my drawing, the have you save it as a dxf or dwg for me and email back to me?
[email protected]
thanks
Malcolm
28-04-2022 #128
Malcolm, I feel your pain. I can try to do what you are after. I will send you my email address by PM so you can send the drawing over. Regards.
30-04-2022 #129
HI
thanks for the reply... please any assistance will be greatly appreciated.
my email
shopsbt at outlook dot com
thanmks
Malcolm
01-05-2022 #130
I have been searching for 1.932 and 1.935 for a while with no luck and really need dxf files exported. If I could get links to the dropbox files that would be very much appreciated.
ZacharyPatel at mail.com
Thanks Zach.
PC Upgrade Options?
By Chaz in forum General DiscussionReplies: 11Last Post: 31-08-2016, 04:53 PM -
Laser Upgrade
By dcrowder in forum Laser Machines & BuildingReplies: 8Last Post: 06-05-2016, 01:06 PM -
VFD upgrade
By paulus.v in forum Spindles & Drive MotorsReplies: 11Last Post: 05-11-2014, 11:09 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM -
BUILD LOG: Time for mk2 upgrade!
By routercnc in forum DIY Router Build LogsReplies: 16Last Post: 26-02-2011, 11:38 PM
