Page 15 of 19 FirstFirst ... 51314151617 ... LastLast
  1. #141
    Chris, I have added you to the Dropbox folder. Good luck with the downloads. Regards.
  2. #142
    If there's a chance you can help me out as well for a previous version: [email protected]
  3. #143
    Should be sorted. I've added you to the Dropbox folder which gives you access to versions 1.932 and 1.935. Good luck.
  4. #144
    Bladevane
    Could you please possibly add me so i could get the older software, made the mistake of upgrading and can't export now, been frantically searching for the older software - [email protected] cheers!
  5. #145
    All sorted. You should have access to versions 1.932 and 1.935 via Dropbox. Regards.
  6. #146
    Quote Originally Posted by Bladevane View Post
    I just wanted to say a big thank you to you for helping me out!
  7. #147
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Please can I get access to that dropbox ?. Thanks
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
  8. #148
    Ace, All sorted.
  9. The Following User Says Thank You to Bladevane For This Useful Post:
  10. #149
    Do you still have the dropbox for version 1.932 and 1.935? Could you add [email protected]?
  11. #150
    Do you still have this dropbox open? If so could you add me to the list [email protected].
  1. PC Upgrade Options?
    By Chaz in forum General Discussion
    Last Post: 31-08-2016, 04:53 PM
  2. Laser Upgrade
    By dcrowder in forum Laser Machines & Building
    Last Post: 06-05-2016, 01:06 PM
  3. VFD upgrade
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 05-11-2014, 11:09 PM
  4. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
  5. BUILD LOG: Time for mk2 upgrade!
    By routercnc in forum DIY Router Build Logs
    Last Post: 26-02-2011, 11:38 PM
