Page 18 of 19 FirstFirst ... 816171819 LastLast
  1. #171
    John,
    Should be OK for you. Let me know if it works, or if it failed.
  2. #172
    it worked perfectly !.
    This is what i did
    (win10) :
    1) I copied the file : ems.dat.1935.txt
    (https://www.mycncuk.com/attachment.p...0&d=1649730249)
    as:
    C:\Users\Administrator\AppData\Roaming\eMachineSho p\ems.dat
    2) I used RunAsDate (https://www.nirsoft.net/utils/run_as_date.html)
    to open emachineshop as date: 30/07/2019
    3) I pressed Ctrl+Alt+e
    Then i could save dxf files.
    Thank you VERY MUCH, Bladevane !!!!
    Kind Regards,
    John
  3. #173
    John, Briliant. Thanks for letting me know. Good luck in your file transfer. I now use FreeCAD for DXF transfer, although other packages are available.
  4. #174
    Hi.
    Would it be possible for me to gain access to an old copy?
    Not sure how this works but I see people previous entered an email address.
    [email protected]
  5. #175
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I still use Emachineshop ( old version). I have yet to find such a simple to use CAD programme (free or for purchase). Just wish the 3D preview would work like it used to. Camabam is good but I find Emachineshop so much easier for designing/drawing. So I use Ems for cad and cambam for cam
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
  6. #176
    Mike, Should be all sorted. Let me know if there are problems and I'll resend. Regards.
  7. #177
    Hi Bladevane!
    Would you be able to add me to the drop box as well? Larsson365 AT live.se
    Best regards
  8. #178
    All sorted. Let me know if you need more. Regards.
  9. #179
    Quote Originally Posted by Bladevane View Post
    Gixer. Sure. Send me your email address and I will add you to the Dropbox folder which has versions 1.932 and 1.935.
    Hey Buddy,
    Can you also add me to the dropbox for these files, cheers
    John
  10. #180
    All should be sorted. Let me know if there are issues.
There are currently 17 users browsing this thread. (0 members and 17 guests)
  1. PC Upgrade Options?
    By Chaz in forum General Discussion
    Last Post: 31-08-2016, 04:53 PM
  2. Laser Upgrade
    By dcrowder in forum Laser Machines & Building
    Last Post: 06-05-2016, 01:06 PM
  3. VFD upgrade
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 05-11-2014, 11:09 PM
  4. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
  5. BUILD LOG: Time for mk2 upgrade!
    By routercnc in forum DIY Router Build Logs
    Last Post: 26-02-2011, 11:38 PM
