Page 7 of 19 FirstFirst ... 5678917 ... LastLast
  1. #61
    Quote Originally Posted by Bladevane View Post
    You now have access to Dropbox and should be able to download versions 1.932 and 1.935. Regards.
    Hello there! I really appreciate what you're doing, could you add me as well?
    [email protected]
  2. #62
    Jordan, All sorted. Regards.
  3. #63
    m100's Avatar
    Lives in Yorkshire, United Kingdom. Last Activity: 15-06-2023 Has been a member for 9-10 years. Has a total post count of 10.
    Many thanks bladevane
    Now if only there was a fix for keeping stl export :-)
  4. #64
  5. The Following User Says Thank You to Big5Axis For This Useful Post:
  6. #65
    w454's Avatar
    Lives in LA FLOTTE, France. Last Activity: 04-01-2025 Has been a member for 3-4 years. Has a total post count of 3.
    Bonjour je suis nouveau sur le forum j'ai le même problème que tout le monde je viens de réinstaller la version à 1.35 voici le lien http://ul.to/ied8ngur
    Translated - Lee
    Hello I am new to the forum I have the same problem as everyone else, I have just reinstalled version 1.35, here is the link http://ul.to/ied8ngur
  7. #66
    w454's Avatar
    Bonjour en installant la version à 1.935 et en mettant comptabilité Windows 8 on peut récupérer les fichiers dxf mais on a pu la fonction vue 3D si quelqu'un la solution ou une idée merci
  8. #67
    Quote Originally Posted by Big5Axis View Post
    For those like me that used STL export primarily there is a workaround.
    Since version V1.946 or V1.947 STL export option expires on June 30 you can used a program that sets the date prior to that date and run eMachineShop with no issue.
    You can find the program here.
    Hope it helps someone else as it did for me. This only help for STL export.
    Hey, I'm not a machinist, and only a 3d printer user, but I just wanted to THANK YOU for this incredibly helpful information. I have been using EMS for years to design 3d parts and the .stl files for my Prusa slicer. After the recent update (no idea why I did that, for something like this, if it works, I usually leave it be...) removed .stl export until a $200 bounty was paid, I tried several design apps and none came close to the ease of use and simplicity EMS provides. So getting that back is tremendous. Were you in sunny florida, I'd buy you a beer.
    Thanks very much. - Mike
    And thanks to Bladevane for getting this thread going.
    (BTW, I actually paid EmachineShop way too much money to fab a part for a FXR, a few years ago, so I don't feel too bad using their app for my own purposes!)
  9. The Following User Says Thank You to mchad For This Useful Post:
  10. #68
  11. The Following User Says Thank You to Big5Axis For This Useful Post:
  12. #69
    w454's Avatar
    Salut à tous. Toujours un peu embêté avec le logiciel mais ça va. Voici mon adresse pour avoir la version à 1.32 Si quelqu'un veut bien me la donner voici mon adresse mail
    [email protected] à toute l équipe
  13. #70
    Benoit, Je vous ai ajouté à Dropbox afin que vous puissiez télécharger les versions 1.932 et 1.935. Après le téléchargement, vous devrez appuyer sur Ctrl + E lorsque vous déroulez la liste des options d'exportation, puis redémarrez eMachineShop. Regards, Glyn.
There are currently 28 users browsing this thread. (0 members and 28 guests)
  1. PC Upgrade Options?
    By Chaz in forum General Discussion
    Last Post: 31-08-2016, 04:53 PM
  2. Laser Upgrade
    By dcrowder in forum Laser Machines & Building
    Last Post: 06-05-2016, 01:06 PM
  3. VFD upgrade
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 05-11-2014, 11:09 PM
  4. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
  5. BUILD LOG: Time for mk2 upgrade!
    By routercnc in forum DIY Router Build Logs
    Last Post: 26-02-2011, 11:38 PM
