    hi chaps, how do you calibrate the x axis of a cnc lathe using mach3 turn. is there a system like there is for setting the steps like mach3 mill. if not how do you do it. thanks,
    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    The same as any other axis.
    Either by calculation, or test/measure/adjust/repeat.
    hi, thanks for getting back, the thing is that mach3 turn does not have the set calibration as mach3 mill. so have can it be the same.
    Quote Originally Posted by terry1956 View Post
    The calibration is essentially the test/measure/adjust/repeat option I mentioned.
    If you want to use the calibration tool, just load the mill screenset, do the calibration, then switch back to the turn screenset.
    thanks.
  1. lathe/4th axis conversion question
    By marbles in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 06-02-2019, 10:06 PM
  2. Mini lathe as a 4th Axis
    By Leadhead in forum Gantry/Router Machines & Building
    Last Post: 24-08-2017, 08:53 AM
  3. 3 axis lathe/mill hybrid design.
    By GordonFreeman in forum Gantry/Router Machines & Building
    Last Post: 08-02-2017, 01:05 AM
  4. 3 axis cnc router lathe?? Help
    By Sooty in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-08-2015, 12:31 PM
  5. 4th Axis running as CNC lathe using milling machine
    By Jonathan in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2011, 10:34 AM
