    Quote Originally Posted by rogw View Post
    Not fixed as yet, I have ruled out interference with the usb cable by using a screened cable.
    I'm still going through the support from the vendor, which is painfully slow I will say, but I have a feeling it is the usb pcb in the control box that's failed as I've tried running it with a difference pc with a fresh software install. I just need them to either send a replacement out, or tell me they won't so I can get things sorted (and upgraded :) ) myself.
    Roger
    No problem but I would still make sure the cables are segregated, have a look in the control box as well and make sure no internal wiring is being effected in the same way.
  2. The Following User Says Thank You to Lee Roberts For This Useful Post:
  3. #2
    I had somewhat similar problem with 3dprinter. Have you tried using different usb port in laptop/computer ?
    In my case windows decided to not recognise my printer on this particular port for some reason.
    Also, ditch all the usb hubs if you're using any - they, for the most part, are an antenna for EM interference... Cheap ones anyway...
  4. The Following User Says Thank You to threedee For This Useful Post:
  5. #3
    rogw's Avatar
    Lives in Yeovil, United Kingdom. Last Activity: 31-07-2024 Has been a member for 5-6 years. Has a total post count of 5.
    Quote Originally Posted by threedee View Post
    I have tried a completely separate pc, no hubs involved on either.
  6. #4
    rogw's Avatar
    I had a peek inside and the cabling looks well separated in terms of high / low voltage. and the motion control board is the opposite end of the box to the transformer and vfd.
  7. #5
    Ok out of interest what Windows version are you running.
    rogw's Avatar
    windows10
  1. 6040Z USB CNC - USB port not recognised.
    By Roy in forum Chinese Machines
    Last Post: 23-05-2021, 10:04 AM
  2. Which Connection ?
    By manofgresley in forum Stepper & Servo Motors
    Last Post: 13-07-2020, 01:55 PM
  3. CNC 6040z USB z-axis
    By Sashido in forum Chinese Machines
    Last Post: 26-03-2018, 09:46 AM
  4. Replies: 46
    Last Post: 26-04-2016, 12:06 AM
  5. Or Guidance ;) Connection Name(s)
    By Carlb1058 in forum Marketplace Discussion
    Last Post: 13-07-2013, 12:48 AM
