    Just wondering about the cnc 3020/3040 variants out there. They seem to require either Mach 3 or Drufel CNC to work, but what would happen if you changed the pcb?
    Is such a board available to enable the use say of Grbl and Fusion 360 etc?
    I don't see why not if the Grbl board can work with the larger working envolope
    going by the photos of 3D printers the 3018 machines they use small plug in 1A stepper drivers like these
    https://www.pololu.com/product/1182
    removing the stepper driver will make the step & direction signals available to operate replacement drivers that can driver the larger motors used on the 3018 machines
    if the Grbl board step and direction outputs are only 3V you may need to buffer them if the new stepperdrivers need 5V pulses
    ( a PC printer port breakout board should do )
    John
    PS
    which Grbl board do you have in mind ?
    PPS
    just found this circuit diagram for one version of a Grbl board
    with plug in A4988 stepper drivers and a plug in Arduino NANO
Name:	Grbl board.png
    PPPS
    another Grbl board with a relay to control the spindle motor
    https://simple-ee.com/2018/06/20/pro...troller-board/
  3. The Following User Says Thank You to john swift For This Useful Post:
    Hi John it was a hypothetical tbh. I was wondering if the 3018-Pro board with drv8825 drivers on would do or if another beat existed.
    Only reason is I'm likely to be getting the 3018 Pro for my birthday late August but depending on finances might be able to go for something with a bit more muscle power wise and rigidity on the motor housing without having to get into Mach 3 or Drufal CNC.
  5. #4
    Not knowing what motors are used on the 3040 machines its hard to predict how well the grbr would drive them
    with the stepper driver output limited to 2A
    the torque will be limited and the low driver supply voltage will limit the speed you can step the motor
    it may be worth looking at using linux instead of a windows PC running Mach 3
    not sure of what the free ware is called
    John
    PS
    http://linuxcnc.org/downloads/
    this is where we need a linux user
  6. #5
    Hi John ironically I've just found several pages devoted to hacking the 3020.
    https://www.instructables.com/id/302...CNC-Shield-V3/
    https://hackaday.com/2015/09/08/how-...e-cnc-machine/
  7. #6
    it looks like the A4899 Stepper Motor Drivers are better than I thought they would be
    after looking at the two links
    the TinyG motion controller shown on the hackaday page looks good
    the only down side is the stepper driver IC's are soldered to the board
    and not an easy DIY replacement
    from that point of view the arduino grbl board on the instructables page
    has an advantage with the plug in drivers
    John
  8. #7
    Yeah part of me would go for the 8825 drivers as they are smoother yet with the smaller increments comes lower torque apparently.
    we'll see what the birthday fairy brings and what extra I can add in the meantime.
  9. #8
    Interestingly this seems to fulfil the mod requirements for the 3020/3040 etc for virtually no money:
    https://www.ebay.co.uk/itm/CNC-V3-Sh...53.m1438.l2649
  10. The Following User Says Thank You to Lol999 For This Useful Post:
  11. #9
    yes
    that will control the motors just like the tinyG for example
    the only thing missing is the FET to switch the spindle motor on and off
    with the arduino cnc sheild you have just linked to you can connect either a FET module or relay module to add the spindle on/off control
Name:	5v relay.jpg
    John
    PS
    check you don't need to add a 5V supply for the arduino
    or 7 to 9V if you use the arduino's built in 5V regulator
    the A4988 can use a 35V supply for the motors so if the 3040 cnc control has a 24V supply for the original stepper drivers that can be reused
    the supply for the TI DRV8825 can be 8.2-V to 45-V
    Last edited by john swift; 04-08-2019 at 03:09 PM. Reason: add ref to arduino 7 - 9V supply
  12. The Following User Says Thank You to john swift For This Useful Post:
  13. #10
    duplicate post
  1. Replies: 1
    Last Post: 24-01-2018, 07:24 PM
  2. DIY 3020 CNC I/O Board
    By Pointy in forum Electronic Project Building
    Last Post: 27-07-2015, 10:48 PM
  3. 3020 / 3040 / generic chinese router accuracy
    By m_c in forum Machine Discussion
    Last Post: 24-07-2014, 11:54 PM
  4. How to change breakout board
    By GeoDurie in forum General Electronics
    Last Post: 23-07-2014, 07:44 AM
  5. WANTED: Has anyone got a Cnc for sale or a cnc 3020 or Cnc 3040 for sale
    By RsvRcarl in forum Items Wanted
    Last Post: 25-02-2013, 07:00 AM
