  1. #9
    yes
    that will control the motors just like the tinyG for example
    the only thing missing is the FET to switch the spindle motor on and off
    with the arduino cnc sheild you have just linked to you can connect either a FET module or relay module to add the spindle on/off control
Name:	5v relay.jpg
    John
    PS
    check you don't need to add a 5V supply for the arduino
    or 7 to 9V if you use the arduino's built in 5V regulator
    the A4988 can use a 35V supply for the motors so if the 3040 cnc control has a 24V supply for the original stepper drivers that can be reused
    the supply for the TI DRV8825 can be 8.2-V to 45-V
    Last edited by john swift; 04-08-2019 at 03:09 PM. Reason: add ref to arduino 7 - 9V supply
  2. The Following User Says Thank You to john swift For This Useful Post:
  1. Replies: 1
    Last Post: 24-01-2018, 07:24 PM
  2. DIY 3020 CNC I/O Board
    By Pointy in forum Electronic Project Building
    Last Post: 27-07-2015, 10:48 PM
  3. 3020 / 3040 / generic chinese router accuracy
    By m_c in forum Machine Discussion
    Last Post: 24-07-2014, 11:54 PM
  4. How to change breakout board
    By GeoDurie in forum General Electronics
    Last Post: 23-07-2014, 07:44 AM
  5. WANTED: Has anyone got a Cnc for sale or a cnc 3020 or Cnc 3040 for sale
    By RsvRcarl in forum Items Wanted
    Last Post: 25-02-2013, 07:00 AM
