Hi I have owned a 6040 CNC machine for about ten years now, but due circumstances I am only now getting to set it up properly. It did run and complete a job but since then I know windows 7 will no longer be updating next year,mach 3 does not like windows 10. Do I upgrade to Windows 10 and to mach 4?
As I have my CNC controller using a parallel cable if I upgrade to mach 4 do I need to change the inards of the controller to accept a usb system? Thanks
04-08-2019 #2
If you use the windows 7 PC just to control the machine and don't let it connect to the internet
you don't neet to change it
"If it aint broke don't fix it" comes to mind
At a later date if your windows 7 PC fails and you have to use a new PC
you can look at using a windows 10 PC and motion controller ,like a UC100 USB Motion Controller ,
that plugs into the machines printer port connector to save modifying the machine
A more expensive and involved upgrade would be to go for some thing like a ethernet smoothstepper
JohnLast edited by john swift; 04-08-2019 at 11:18 AM.
04-08-2019 #3
Hi John. I think I'm looking to sort it with the least amount of grief and the most amount of longevity. I heard people having hassle going from parallel to usb so if it meant a bit of modification to cater for the usb I don't mind investing.
04-08-2019 #4
I think you'd find a lot of support to upgrading to Ethernet, rather than USB - there are some people here that have had problems with intermittent issues with USB in a high electrical noise environment. To this end, the admirable UC100 can be replaced instead with the EC300ETH, EC400ETH or AXBB-E devices from CNCDrive - works well with Mach3 and their own UCCNC software. These can plug directly (with suitable cable, of course) into the existing parallel interface that you have on your controller.
06-12-2019 #5
06-12-2019 #6Puruvesi Automation engineer working on the myCNC project.
09-01-2020 #7
04-08-2019 #8
Thanks Doddy, I'm taking all and any advice on this as it's an investment for me to hopefully grow into something decent.
04-08-2019 #9
If it were mine I would avoid Windoze 10 like the plague. I've had 2 apps stop working in the last 9 months after Windoze decided (even though I had automatic updates notionally switched off) to "upgrade" itself. Microsoft obviously have a "if it ain't broke, nobble it" kind of attitude.
06-12-2019 #10
Give us a picture inside your control box to help us understand what you have.
You can find a recommended wiring scheme on the CNC Drive website. If you understand that, and understand what's in the control box then you should be able to work it out easily.
What is your opinion of the CNC 6040 Router Machine ?
By John S in forum Chinese MachinesReplies: 7Last Post: 30-11-2023, 10:58 AM -
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
DIY 6040 CNC - advice required!
By Pointy in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 14-09-2016, 12:05 PM -
Machine better than a chinese 6040 for a beginner?
By d4cnc in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 09-11-2015, 12:47 PM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM
