    Hi I have owned a 6040 CNC machine for about ten years now, but due circumstances I am only now getting to set it up properly. It did run and complete a job but since then I know windows 7 will no longer be updating next year,mach 3 does not like windows 10. Do I upgrade to Windows 10 and to mach 4?
    As I have my CNC controller using a parallel cable if I upgrade to mach 4 do I need to change the inards of the controller to accept a usb system? Thanks
    If you use the windows 7 PC just to control the machine and don't let it connect to the internet
    you don't neet to change it
    "If it aint broke don't fix it" comes to mind
    At a later date if your windows 7 PC fails and you have to use a new PC
    you can look at using a windows 10 PC and motion controller ,like a UC100 USB Motion Controller ,
    that plugs into the machines printer port connector to save modifying the machine
    A more expensive and involved upgrade would be to go for some thing like a ethernet smoothstepper
    John
    Hi John. I think I'm looking to sort it with the least amount of grief and the most amount of longevity. I heard people having hassle going from parallel to usb so if it meant a bit of modification to cater for the usb I don't mind investing.
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    I think you'd find a lot of support to upgrading to Ethernet, rather than USB - there are some people here that have had problems with intermittent issues with USB in a high electrical noise environment. To this end, the admirable UC100 can be replaced instead with the EC300ETH, EC400ETH or AXBB-E devices from CNCDrive - works well with Mach3 and their own UCCNC software. These can plug directly (with suitable cable, of course) into the existing parallel interface that you have on your controller.
    Hi Doddy. Is getting say the AXBB-E , a big deal or is it fairly doable for someone semi competent. Do i need to pull stuff out of my existing controller (boards etc) I managed to exchange a faulty motor driver without any drama.
  6. Quote Originally Posted by Doddy View Post
    This might be preaching to the choir, but I just wanted to echo the Ethernet sentiment.
    Puruvesi Automation engineer working on the myCNC project.
    I've experienced a lot of problems with USB. After trying lots of methods to shield it, by far the most effective fix has been to ditch the cheap USB lead and replace it with a quality lead with gold contacts and a ferrite choke at both ends.
    Thanks Doddy, I'm taking all and any advice on this as it's an investment for me to hopefully grow into something decent.
    If it were mine I would avoid Windoze 10 like the plague. I've had 2 apps stop working in the last 9 months after Windoze decided (even though I had automatic updates notionally switched off) to "upgrade" itself. Microsoft obviously have a "if it ain't broke, nobble it" kind of attitude.
    Doddy's Avatar
    Give us a picture inside your control box to help us understand what you have.
    You can find a recommended wiring scheme on the CNC Drive website. If you understand that, and understand what's in the control box then you should be able to work it out easily.
  1. What is your opinion of the CNC 6040 Router Machine ?
    By John S in forum Chinese Machines
    Last Post: 30-11-2023, 10:58 AM
  2. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  3. DIY 6040 CNC - advice required!
    By Pointy in forum Gantry/Router Machines & Building
    Last Post: 14-09-2016, 12:05 PM
  4. Machine better than a chinese 6040 for a beginner?
    By d4cnc in forum Gantry/Router Machines & Building
    Last Post: 09-11-2015, 12:47 PM
  5. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
