Does anyone know if thread milling would work in 303 ?
Does it need multiple passes therefore may work harden?
At least if the tap broke the work is recoverable
06-08-2019 #2
303 taps nicely with Spiral Point and Spiral Flute taps of the right type and with the correct drill size, which will never be nominal OD less pitch BTW.
You will only get hardening if you fail to take a decent DOC, I've never had 303 harden on me.You think that's too expensive? You're not a Model Engineer are you? :D
06-08-2019 #3
yes thread milling will work in 303. if I had to thread mill them with the small sizes of thread I would do them in one cut with a micro thread mill. personally though I would roll tap the threads as it will create no swarf to get stuck in the tap and 303 forms very well
07-08-2019 #4
If your having problems with tapping like previous posts have mentioned a slightly oversized drill or threadmilling theres a supplier selling threadmills on a promo
www.smarttoolsuk.com starting at £32.50 had good feedback on them from the floor 2-3 passes i reckon on 303
RFQ: Stainless motorcycle wheel spacers
By stuartpurdue in forum Projects, Jobs & RequestsReplies: 1Last Post: 29-06-2017, 03:11 PM -
stainless bar?
By kingcreaky in forum General DiscussionReplies: 3Last Post: 12-02-2016, 09:17 PM -
RFQ: Water or laser cut stainless flanges
By r0bsk1 in forum Projects, Jobs & RequestsReplies: 2Last Post: 23-09-2013, 08:12 PM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
How to cnc cut 1-2mm stainless sheet ??
By Ricardoco in forum Metalwork DiscussionReplies: 9Last Post: 28-03-2013, 04:06 AM
