Thread: Two Machines from one PC
09-08-2019 #11
I am long term friends with owner of Computer Services Nottingham. If my Mach 3 PC crashed, I would get an old machine for free, that somebody has traded in and load it up with my software from the mirrored NAS box. I speak from experience. That way you get a PC good enough to run the fairly low demands of Mach3 and with a parallel port.
My systems are all networked and the Mach3 machine has the Internet Gateway disabled, so no stupid interruptions. All my Gcode is generated on my Win10 machine and filed in the NAS box, so a hard drive failure on the CNC machine has low impact.
Even my 3D Printer has a Wifi enabled SD card, so I can download to it easily.
09-08-2019 #12
See how it goes, but a fundamental misunderstanding of how Mach3 works with the PP seems to be at the heart of the assumption that this will not be problematic.
09-08-2019 #13
10-08-2019 #14
15-08-2019 #15
And it works!
Ran both machines today cuting fresh air from the same PC for several hours without any issues. The only thing I still need to do is connect 2 keyboards and mice to the PC.
15-08-2019 #16
Then you will need a KVM, but be careful you get one that operates backwards as they are normally 1 Kb & Mouse for 2 PCs - you would be better off with a mechanically switched one. Like this one https://www.amazon.co.uk/Sienoc-Port...c-fefa6b9989e1 although the sockets are the wrong way round
15-08-2019 #17
I am hoping I wont need a KVM as I already have both of the monitors working and I am led to believe Windoze wil work with 2 keyboards and 2 mice connected at the same time. Will find out if it is true tomorrow.
15-08-2019 #18
17-08-2019 #19
Why would you use 2 keyboards if you have only one computer and screen? I hope you don't expect the two software to run in one window each and believe that you can allocate one keyboard to each and control them independently. Ms windows allows only one to be active so what's the point of two keyboards?
17-08-2019 #20
NEW MEMBER: art (ugh!) + machines
By jeronimo in forum New Member IntroductionsReplies: 2Last Post: 12-11-2016, 10:23 AM -
EDM machines.
By gavztheouch in forum Machine DiscussionReplies: 11Last Post: 01-11-2014, 12:38 AM -
CNC machines
By JMP in forum Machine DiscussionReplies: 2Last Post: 04-07-2010, 07:40 PM -
New CNC machines???
By afcpaul in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 18-09-2009, 01:46 PM -
TEP CNC Machines
By alan2525 in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 05-02-2008, 01:04 PM
