Thread: Two Machines from one PC
08-08-2019 #6
One of the things to watch out for is the speed of each machine; I would anticipate that both will work, but they'd both slow down a bit as the USB and Parallel communications each need to perform CPU interrupts (literally what it says on the can - a message comes in, and it forces the CPU to stop what its doing and handle this right now), which might not play well together.
The other issue I see is that with a system running off the parallel port, if there is no command buffer, it relies upon the real-time element to work correctly. Imagine if you're half way through a diagonal move which requires synchronised movement of X and Y, but your PC has to deal with something else halfway between sending these signals - you might get a not so diagonal line - but this is purely speculation! I'm looking forward to hearing about your results :)
NEW MEMBER: art (ugh!) + machines
By jeronimo in forum New Member IntroductionsReplies: 2Last Post: 12-11-2016, 10:23 AM -
EDM machines.
By gavztheouch in forum Machine DiscussionReplies: 11Last Post: 01-11-2014, 12:38 AM -
CNC machines
By JMP in forum Machine DiscussionReplies: 2Last Post: 04-07-2010, 07:40 PM -
New CNC machines???
By afcpaul in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 18-09-2009, 01:46 PM -
TEP CNC Machines
By alan2525 in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 05-02-2008, 01:04 PM
