    Best would be 2 machine and no PC. Each machine its own controller. Why people love so much mach3 when dedicated controllers are so much better and cheap nowadays, i dont get it. Obviously the desire for suffering...
    And it works!
    Ran both machines today cuting fresh air from the same PC for several hours without any issues. The only thing I still need to do is connect 2 keyboards and mice to the PC.
    Quote Originally Posted by ngwagwa View Post
    And it works!
    Then you will need a KVM, but be careful you get one that operates backwards as they are normally 1 Kb & Mouse for 2 PCs - you would be better off with a mechanically switched one. Like this one https://www.amazon.co.uk/Sienoc-Port...c-fefa6b9989e1 although the sockets are the wrong way round
    I am hoping I wont need a KVM as I already have both of the monitors working and I am led to believe Windoze wil work with 2 keyboards and 2 mice connected at the same time. Will find out if it is true tomorrow.
    You're correct, absolutely no need for a KVM.
    Sent from my SM-G950F using Tapatalk
    Why would you use 2 keyboards if you have only one computer and screen? I hope you don't expect the two software to run in one window each and believe that you can allocate one keyboard to each and control them independently. Ms windows allows only one to be active so what's the point of two keyboards?
    He has one computer, but two screens. Placing the screens at different sides of the workshop and you can use that computer from either of the locations is what I assume he's doing.
  1. NEW MEMBER: art (ugh!) + machines
    By jeronimo in forum New Member Introductions
    Last Post: 12-11-2016, 10:23 AM
  2. EDM machines.
    By gavztheouch in forum Machine Discussion
    Last Post: 01-11-2014, 12:38 AM
  3. CNC machines
    By JMP in forum Machine Discussion
    Last Post: 04-07-2010, 07:40 PM
  4. New CNC machines???
    By afcpaul in forum Milling Machines, Builds & Conversions
    Last Post: 18-09-2009, 01:46 PM
  5. TEP CNC Machines
    By alan2525 in forum Milling Machines, Builds & Conversions
    Last Post: 05-02-2008, 01:04 PM
