View Poll Results: Which profiles should I use?
- Voters
- 1. You may not vote on this poll
40 series aluminium profiles (80x80 and 80x160)
0 0% -
45 series aluminium profiles (90x90 and 90x180)
1 100.00%
Thread: Choosing aluminium profiles
12-08-2019 #21
I used heavy duty item 24 profile, very good quality product:)
12-08-2019 #22
There are many topics on epoxy on this forum. Somewhere on my second build i have explained very profoundly my experience. Westsystem epoxy, slow cure.
90x90 aluminum i think was same as 100x100x3 or 4mm steel. So no worry. But if steel weld it, if aluminum, bolt it.
At the end time and money spend is same, but if you have more time than money =steel, if you have more money than time=aluminum. Thats the truth for me.
3 Days Ago #23
ChatGPT said: Go with the 45 series profiles. They’re stiffer, more robust, and the Power-lock system makes assembly much easier. The extra cost is worth it for precision and long-term rigidity, especially for a moving gantry CNC that will machine aluminum and occasional steel. The 40 series could work with reinforcement, but 45 series is the safer, more reliable choice.
cnc crashes when cutting 2D profiles in wood
By chrisobrien07 in forum Woodwork DiscussionReplies: 10Last Post: 16-11-2021, 09:38 PM -
Rigidity of aluminium profiles and rectangular tube sections....
By Voicecoil in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 14-10-2018, 01:51 PM -
A good supplier in UK for Aluminium profiles
By suspension in forum Marketplace DiscussionReplies: 0Last Post: 07-12-2017, 02:46 PM -
Milling Continuous Profiles?
By Tenson in forum DolphinReplies: 3Last Post: 15-02-2012, 04:53 PM -
Aluminium Profiles
By wizer in forum General DiscussionReplies: 10Last Post: 10-03-2010, 11:41 AM
