Page 5 of 8 FirstFirst ... 34567 ... LastLast
  1. #41
    Just a quick update...
    John repaired the AXBB for me by replacing the faulty Fet. It's all back up and running now. Cheers guys and especially John.
    Sent from my SM-G920F using Tapatalk
  2. #42
    Quote Originally Posted by CharlieRam View Post
    Good to hear you got it fixed.
    Do you know what broke it?
    Grtz Bert
  3. #43
    If the FET blew due to back EMF from the relay coil, then it's a bit naughty as the AXBB-E manual shows a direct connection with no added clamp diode Funny, I was just about to email Balazs to ask whether such diodes were included on the board, I'll let you know what he says.
  4. #44
    I have no idea i have checked the wiring and all looks ok although I have removed all the switch light outputs just in case that was the cause... I've protected it now with a 7001n diode across the relay and a 27ohm resistor on the charge pump output so hopefully it will be ok now.
  5. #45
    It is not easy to tell what the problem was
    a case of no fault found that could of damaged the FET
    As the relay worked when the wire from the AXBB output was connected to the -24V supply
    you can only suspect either there was an intermittent short connecting the +24V supply to the AXBB output
    or
    an intermittent open circuit that generated a sustained back emf that over stressed the diode in side of the NTR5198NL-D FET
    or may be it was a faulty FET
    John
    PS
    the diode added across the relay coil and a 27ohm resistor in series with the relay coil
    will help to protect the AXBB output
    the resistor limiting the current if coil is short circuited
    and the diode clamping the back emf when the relay is switched off
  6. #46
    Hi Voicecoil
    The diagram in post 40 shows the signal path through the circuit after the HCPL-2631 opto isolators
    the only diode is within the NTR5198NL-D FET
    hence my comment in post 30
    “Its a pity they had not used a DIL (dual in line ) octal transistor array like the ULN2803
    or a new FET array
    like the Toshiba TB D62381A series DMOS transistor array
    that would enable the user to plug in a replacement “
    the Gecko G540 has the same issue with a FET that's soldered in
    John
  7. The Following User Says Thank You to john swift For This Useful Post:
  8. #47
    Quote Originally Posted by john swift View Post
    Hi Voicecoil
    or a new FET array
    John
    Well in that case the manual really should show a clamp diode in parallel with the relay coil IMHO. The intrinsic body diode in the FET will be sod-all use for a coil that's connected between the output and +24 as it'll shoot a long way positive when the FET switches off and over-voltage it in the process. The great thing about drivers like the ULN2803 you mentioned is that they have the clamp diodes built into the chip which makes it a lot less likely that they'll blow. I'll be adding some diodes to all my relay outputs tomorrow.
  9. #48
    it seems strange that the software will allow me to choose any output for the charge pump though.
    A little late, but just wanted to clarify.
    Yes, you can assign the charge pump signal to any output. But the charge pump signal is a PWM signal. Only Port 1 Pin 1 has circuitry to convert the PWM signal to an on/off state. If you assign the charge pump to a different output, you'll just get the PWM signal on that output, which will not switch a relay.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  10. #49
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Of course... you may want to use the PWM charge-pump output to control an existing, external charge-pump.
  11. #50
    Hi Gerry
    Thank you for the missing detail
    that makes sense of the test results when Charlie tried using another output
    John
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. CNCDrive AXBB super deal?
    By driftspin in forum CNCdrive (UC100, UC300ETH)
    Last Post: 16-03-2019, 10:10 PM
  3. Not sure where the fault lays
    By terry1956 in forum Vectric
    Last Post: 20-02-2019, 11:28 AM
  4. fault testing
    By Palletlad in forum General Computing
    Last Post: 09-02-2018, 05:51 PM
  5. Jun-Air Compressor Fault
    By jamesgates1000 in forum General Discussion
    Last Post: 02-12-2017, 07:59 PM
