Thread: AXBB charge pump fault
The SVGA extension cable - there's a couple of no-connection lines in there - perhaps if those aren't wired-through it explains the inability to work. A straight-through 15-w D-type M-F should work without too much drama. Not sure what you mean by the USB controller - unless this is a Windows->pendant interface?, in which case, again, the lack of cabling may possibly explain that (not sure).
The FET behaviour, as described, is borked.
18-11-2019 #2
Sorry...i should of explained better. The pendant was one of these...
https://rover.ebay.com/rover/0/0/0?m...2F163108997386
The mpg is wired to inputs on the AXBB but the axis and jograte selectors are wired to a usb controller due to the lack of inputs on the AXBB. The svga wire was advertised as fully wired so I assumed that meant each pin was individually wired but I don't think it Is!
Sent from my SM-G920F using TapatalkLast edited by CharlieRam; 18-11-2019 at 08:40 PM.
17-07-2021 #3
It seems concerning that, regardless of the reason, failure of the charge pump output can result in an estop being ignored. I was planning on replicating OP's design with the charge pump output controlling my contactor. Now I'm not so sure. What are your thoughts on this?
17-07-2021 #4
1) This is the only instance I've heard of of the Charge Pump output failing.
2) Use a Safety relay to control your contactor, with the charge pump signal as part of an E-Stop circuit controlling the safety relay. Any E-stop drops the safety relay, which drops the contactor.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
17-07-2021 #5-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
17-07-2021 #6
Thanks! The e-stop design has given me quite a headache. My main design goals are:
1. Ideally I want any e-stop signal to be able to drop the contactor, even one from a pendant. That means the e-stop circuit has to monitor the reset status of UCCNC. This also means I'm covered in two ways in light of an accident. First the AXBB-E will stop sending pulses, then power will be cut to the motor's PSU. The safety relay connected to the contactor achieves this - although I'm not clear why I need an extra relay in the system if I have a 24v coil on the contactor? Is it just a way of adding the switches in parallel instead of in series? I've seen circuits (such as https://youtu.be/6dKwOsrnkb4) that build a no volt release just using a contactor.
2. I also want any e-stop to put UCCNC into reset mode which means the AXBB-E needs to monitor the status of the e-stop circuit.
3. The contactor should stay off following power outage and require a manual button press to re-energize the coil.
My conclusion was the only way to accomplish this without getting stuck in a feedback loop between 1 and 2 was to connect all e-stops to the AXBB-E then have it control a relay with the charge pump output pin as shown in the example circuit at the end of the manual. Does that seem like the right approach to you all? I really appreciate your help!
17-07-2021 #7
You can only incorporate the pendant in the E-stop circuit if it's a wired pendant, a wireless one is software-driven and will only put UCCNC into Reset mode and not do a hardware E-stop which is the correct way.
Also, the E-stop circuit doesn't and shouldn't be driven by software so you don't monitor UCCNC you inform it an E-stop occurred using inputs.
You don't actually need a safety relay and can indeed just use the contactor wired in a latching circuit, however, using a separate Relay gives more control. It doesn't need to be a safety relay either just an ordinary ICECUBE type relay works just fine.
This relay is known as the MASTER relay in the circuit because it controls all the safety and won't be allowed to energize unless all the safety on your machine is correct.
Only when all is correct on the machine will the MASTER relay be allowed to latch, When it does it will do several things.!
#1 sends a signal to UCCNC saying it's ok to allow a Reset.
#2 power the contactor for the drives.
#3 power any other contractors in your system or allow voltage to reach contractors or relays ie: For dust extraction
#4 Turn on any LED's ie: light tower etc
#2 As mentioned above, you inform the AXBB-E using inputs rather than it doing the monitoring. If it sees the input HIGH or LOW depending on how you configure the input then it won't allow the software to RESET.
#3 This is known as a latching Circuit and is easily done using a relay.
The Charge pump Output is not designed for this purpose, it's designed to monitor the connection between PC and controller so if the software crashes or PC dies the AXBB-E sees this and disables the Output. This, in turn, would drop the relay which should be incorporated into the E-stop circuit and before the MASTER relay.-use common sense, if you lack it, there is no software to help that.
17-07-2021 #8
Sorry old friend, didn't see the email.
Had a bad back earlier this year that put me out of commission for about 6 weeks. And projects at the new house have kept me incredibly busy.
The screenset is at the top of my todo list, as soon as I can find the time. Trust me, I want it done as much as everyone else.Gerry
18-07-2021 #9-use common sense, if you lack it, there is no software to help that.
18-07-2021 #10
I've just had 2 spinal nerve block injections, so you're not alone guys
I also need to figure out my estop circuit and wire up all my inputs next. I'll be looking through all the advice that's been given.
No £5 bob's this time, hope to do this one properly.
(Even though my box has turned out to be a little small
) Balls!.
Advice on a charge controller please :)
By blackburn mark in forum General ElectronicsReplies: 23Last Post: 04-05-2020, 07:28 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
Not sure where the fault lays
By terry1956 in forum VectricReplies: 5Last Post: 20-02-2019, 11:28 AM -
fault testing
By Palletlad in forum General ComputingReplies: 2Last Post: 09-02-2018, 05:51 PM -
Jun-Air Compressor Fault
By jamesgates1000 in forum General DiscussionReplies: 5Last Post: 02-12-2017, 07:59 PM
