I having read the manual again I see the charge pump controls the damaged output 1
Not all outputs as I thought last night !
which breakout board are you thinking of using ?
To add another charge pump you need to use a breakout board with a built in charge pump circuit or
something like cnc4pc's C4
https://www.cnc4pc.com/c4-safety-charge-pump.html
the detector circuit is hidden under the board !
You need the circuit that controls the relay to ignore static logic levels
and only detect the 10Khz charge pump signal
older version
https://www.cnc4pc.com/pub/media/pro...ser_manual.pdf
Name:	C4 SAFETY CHARGE PUMPBOARDRev. 6.2.jpg
John
