    yes , I think the AA6 is faulty
    the first file is just a PDF copy of the 74HC14 data sheet
    As the same AA6 transistor is used for all 8 opto-isolated outputs
    the only obvious differance I can see is the charge pump has control of output 1
    and you via mach 3/4 control of the other 7 outputs
    any output should be able to control a relay
    John
    PS
    looking back at an earlier post
Name:	port 1 pin 1 charge pump assignment.jpg
    I would of thought you should be able to change port 1's charge pump to another pin
    for example to pin 2
Name:	port 1  charge pump assignment to pin 2.jpg
    John
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. CNCDrive AXBB super deal?
    By driftspin in forum CNCdrive (UC100, UC300ETH)
    Last Post: 16-03-2019, 10:10 PM
  3. Not sure where the fault lays
    By terry1956 in forum Vectric
    Last Post: 20-02-2019, 11:28 AM
  4. fault testing
    By Palletlad in forum General Computing
    Last Post: 09-02-2018, 05:51 PM
  5. Jun-Air Compressor Fault
    By jamesgates1000 in forum General Discussion
    Last Post: 02-12-2017, 07:59 PM
