    The belt and braces approach of adding a diode across the relay coil works for me
    ( As long as you have it the correct way round )
Name:	AXBB isilated output.jpg
    I would look for a wiring problem that could of shorted the +24V to the AXBB output
    As semiconductors fuse faster than expensive fuses thats supposed to protect them
    you could try adding a 22 ohm 1/4W resistor in series with the relay coil
    ( the resistor should only fail if the relay coil is shorted )
    The only issue I would expect with tripping the RCD will be corrupting the PC hard drive
    If you have not shut the PC down
    John
    Last edited by john swift; 15-08-2019 at 12:29 AM. Reason: add ref to adding 22 ohm 1/4 W resistor
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. CNCDrive AXBB super deal?
    By driftspin in forum CNCdrive (UC100, UC300ETH)
    Last Post: 16-03-2019, 10:10 PM
  3. Not sure where the fault lays
    By terry1956 in forum Vectric
    Last Post: 20-02-2019, 11:28 AM
  4. fault testing
    By Palletlad in forum General Computing
    Last Post: 09-02-2018, 05:51 PM
  5. Jun-Air Compressor Fault
    By jamesgates1000 in forum General Discussion
    Last Post: 02-12-2017, 07:59 PM
