    Quote Originally Posted by john swift View Post
    The BOB you have linked to does not have the charge pump / watchdog circuit needed
Name:	ebay CNC BOB (2).jpg
    pin 17 just switches the relay on when the pin is taken high ( +5V )
    one DIY circuit from Geckodrive.com
    John
    Oh...my understanding was that the AXBB watched for the signal from the pc and then activates a chosen output for the charge pump. In my case it would be pin 17 controlled through the AXBB's 26pin idc to the bob which would then switch the onboard relay on to complete the circuit to power my safety relay for the drives.
    Am I understanding it wrong? There should be no random outputs on the AXBBs port 3 lile would be on a pc's parallel port on start up or at least that's what I assumed.
    Sent from my SM-G920F using Tapatalk
    last night I expected the AXBB to work as you described but after downloading the manual
    at the bottom of page 19
    8.1.1 .Digital isolated ports.
    Port#1 pins 2. to 8. are isolated outputs. These outputs contain high speed 10Mbit/sec
    optocouplers and an N-channel Mosfet transistors.
    The outputs can drive upto 500mAmps of current upto 24Volts voltage levels.
    The high current capability of the output transistors makes these outputs ideal to drive
    relays, solid state relays and other signals which require isolation.
    19/29
    on page 21
    8.3 .Charge pump safety circuit port
    There is one charge pump safety circuit integrated on the board in port#1 O1 CHP output.
    The charge pump circuit senses the charge pump pulse stream signal from the controller and
    if the signal exists then the output is switched on and if it cuts then the output switches off.
    The charge pump can be used to control a safety relay to cut power when the software is not running on the computer.
    Unless I have missed it
    I have not seen an explicit ref to all output being switched off as I would of expected
    My be another AXBB user can confirm
    John
    PS
    have you contacted the manufactures ?
    19/29
    on page 21
    John
    PS
    I think I will have to, I just wanted to check I hadn't missed anything. It was working fine and I'm not sure when it turned faulty but noticed a few days ago that it started straight away it seems strange that the software will allow me to choose any output for the charge pump though.
    Cheers for the help
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. CNCDrive AXBB super deal?
    By driftspin in forum CNCdrive (UC100, UC300ETH)
    Last Post: 16-03-2019, 10:10 PM
  3. Not sure where the fault lays
    By terry1956 in forum Vectric
    Last Post: 20-02-2019, 11:28 AM
  4. fault testing
    By Palletlad in forum General Computing
    Last Post: 09-02-2018, 05:51 PM
  5. Jun-Air Compressor Fault
    By jamesgates1000 in forum General Discussion
    Last Post: 02-12-2017, 07:59 PM
