    the board is very much what I expected
    basically an all in one UC300 and opto isolated breakout board from what I can see
    looking at your photo
    the 10K resistor is in parallel with
    the 200 ohm resistor that's in series with the FETs gate & drain connections
    your probably seeing the 220 ohms in series with the short circuited FET gate & source
Name:	FET CONNECTIONS.jpg
ID:	26205 Click image for larger version.
Name:	FET  connection  circuit.jpg
    I expect the 2K resistor is probably limiting the indicator LED current
    whats the 14 pin IC number that you can just see 7 of its pins ?
    John
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. CNCDrive AXBB super deal?
    By driftspin in forum CNCdrive (UC100, UC300ETH)
    Last Post: 16-03-2019, 10:10 PM
  3. Not sure where the fault lays
    By terry1956 in forum Vectric
    Last Post: 20-02-2019, 11:28 AM
  4. fault testing
    By Palletlad in forum General Computing
    Last Post: 09-02-2018, 05:51 PM
  5. Jun-Air Compressor Fault
    By jamesgates1000 in forum General Discussion
    Last Post: 02-12-2017, 07:59 PM
