Thread: AXBB charge pump fault
Hi Voicecoil
The diagram in post 40 shows the signal path through the circuit after the HCPL-2631 opto isolators
the only diode is within the NTR5198NL-D FET
hence my comment in post 30
“Its a pity they had not used a DIL (dual in line ) octal transistor array like the ULN2803
or a new FET array
like the Toshiba TB D62381A series DMOS transistor array
that would enable the user to plug in a replacement “
the Gecko G540 has the same issue with a FET that's soldered in
John
The Following User Says Thank You to john swift For This Useful Post:
09-09-2019 #2
Well in that case the manual really should show a clamp diode in parallel with the relay coil IMHO. The intrinsic body diode in the FET will be sod-all use for a coil that's connected between the output and +24 as it'll shoot a long way positive when the FET switches off and over-voltage it in the process. The great thing about drivers like the ULN2803 you mentioned is that they have the clamp diodes built into the chip which makes it a lot less likely that they'll blow. I'll be adding some diodes to all my relay outputs tomorrow.
Advice on a charge controller please :)
By blackburn mark in forum General ElectronicsReplies: 23Last Post: 04-05-2020, 07:28 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
Not sure where the fault lays
By terry1956 in forum VectricReplies: 5Last Post: 20-02-2019, 11:28 AM -
fault testing
By Palletlad in forum General ComputingReplies: 2Last Post: 09-02-2018, 05:51 PM -
Jun-Air Compressor Fault
By jamesgates1000 in forum General DiscussionReplies: 5Last Post: 02-12-2017, 07:59 PM
