12-04-2023 #321
My wire version I used for straightening a rail that was already sitting in plane with its pair since the surface had been epoxy leveled, it was looking down on the wire from above so gravity wasn't an issue. Your setup will work for a single rail in 1D as you have it setup in the video with the laser firing down the rail but you couldn't use it for bringing things into plane as the laser surface is not flat enough. You need a really expensive lens for generating a flat surface, if you look up commercial products for leveling machines in this way you can see the price of the laser source, that is all going into the lens.
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
