Hi John,
With a self levelling laser hitting a 2mm square target over the entire machine shouldn't be too hard assuming you have levelling feet on the machine, we all do this or better when we put up a shelf. This assumes we can weld the frame to within 2mm.
Should also be noted that it is only the vga (640x480) web cams that have this small sensor area I think these are 1/6" diagonal sensors, other similarly priced but higher resolution cams have larger sensor areas. For example the raspberry pi camera (1/4") has a 4.6mm diagonal and another sensor I have the OV2640 has 4.5mm. It seems that the sensors are classified by the diagonal size of the sensor of which the active area with the pixels is smaller, this is why 1/4" > 4.6mm.
I like the idea of levelling a jig then grinding the surface as an alternative to shimming. What sort of grinder would you use for this?
I can imagine a jig short jig say 500mm that clamps around a piece of box section that can be micro adjusted for twist and level. I we bolted aluminium to the top of the box section you could probably skim it with a hand router with a small fly cutter in it. Skim the section under the jig then move the jig along, re-align it with the laser/wire then repeat. When you finish one rail then move the assembly to the other without moving the reference laser to bring the other rail into plane. Maybe a wood power planer could be used for the skimming, would be scary though.
The jig itself needs to be planar as you say but this should be straight forward on a milling machine.
What are you thinking for differentiating twist from height variation? I think with the laser two image sensors stuck out each side could detect twist same when you tram a mill with two dial indicators on a T bar in the spindle.
Cheers, JoeLast edited by devmonkey; 18-08-2019 at 10:56 AM.
18-08-2019 #2
18-08-2019 #3
The Following User Says Thank You to devmonkey For This Useful Post:
19-08-2019 #4
It looks like the camera approach proposed by Devmonkey can solve two problems.
Generating an accurate plane surface with a Laser and camera as you have shown in his illustration
Or
Using stretched wire and camera's as a reference to machine a flat surface.
A great mind meld!
PS: I have located a scrap beam from a building site. I will have to weld up an adjustable base to keep it vertical. :)
Regards
JohnLast edited by John McNamara; 19-08-2019 at 03:26 AM. Reason: Typos!
19-08-2019 #5
19-08-2019 #6
19-08-2019 #7
A little earlier I was tempted to ask, tongue somewhat in cheek, how, once the long ( X axis in my case) rails are aligned, we now extend these techniques to setting up the gantry. After a little more serious thought I came up with the following. The required equipment is satisfyingly simple and inexpensive. Sorry for a lack of drawings, I'm not at home among all my toys at present and I'm thinking and editing this as I write it. All comments and corrections gratefully received.
Depending on your design, the same principles discussed earlier might be used to align the pairs of Y and Z axes rails when building the parts on the bench but we then need to square the gantry and tram the Z axis to bring everything together. Wanting to test for misalignment of rail pairs due to the stress of assembling the parts adds even more complication.
I'm thinking that two taught wires (one in front of and one behind the gantry) stretched across the now perfectly aligned X rails could be used with a simple threaded sensor probe mounted in an offset bracket in the spindle in much the same way as a single dial gauge is commonly used for tramming but without the awkward setting up and possible errors of a glass plate sitting on the machine bed. For machines with the rails mounted on high sides this might not work. Design your next machine with your chosen alignment procedures already devised.
One complication is that the wires must be perpendicular to the X rails and very close to the exact spacing required to give contact points with the probe arm parallel to the X axis or measured errors will be a compound of several possible alignment errors in the machine. By rotating the probe and adjusting it's height it is possible to use an ordinary multimeter to detect a setting where the probe just fails to make electrical contact with the wires at both front and back. If the spindle axis is not perpendicular to the X rails in the vertical plane these heights will not match. Unfortunately we can’t tell from these measurements if it’s the gantry feet that need shims or the spindle mounting.
Testing at either end of the Y axis travel will check for any twist in the Y rails plane and variation of height above the X plane (I'm calling this 'Y axis tilt' ). At least we know where the shims go for these last two. All these errors will need to be corrected before moving on.
I'm thinking of using a threaded probe rather than play with the software-driven Z axis height to do this as it's going to be quicker and easier.
Your chosen gantry design means it may not be possible to position the axis of the spindle in the ideal position directly above one wire and check for two matching contact heights at two points either side of the spindle along the Y axis but any two points on one wire found by moving the sensor over as wide an arc as possible over a wire as close to the spindle as possible should work. Height differences measured here are only due to errors within the Z axis/spindle assembly alignment if there is no remaining Y axis tilt.
Only after all this is done is it possible to skim the bed and then square the gantry by making the machine mark the corners of a rectangle on the bed and comparing the length of the diagonals.
KitLast edited by Kitwn; 19-08-2019 at 10:03 AM.
19-08-2019 #8
I've put the software up on github if anyone wants to play, I will add features as I need them or they are suggested here.
https://github.com/betzuka/laserlevel
The Following 3 Users Say Thank You to devmonkey For This Useful Post:
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
