01-09-2019 #9
Hi Bert,
The sensor in your cam is probably fine, although if the overall dimension of the camera is only 8mm it maybe harder to work with. The VGA sensors we are using are 2mm across.
It seems most of the cheap cameras are vga even though they are sold as HD. It is difficult to determine what the actual resolution of the sensors are without a part number, some are probably higher resolution sensor that are binned to get VGA output. We want a reasonable frame rate for averaging so given the bandwidth constraints of USB2 which most of the cameras talk, VGA can be give us 30FPS.
If you take a 2mm sensor with 640 columns of pixels you get 3um per row which is plenty small enough for what we are doing.
My laser doesn't lock in position, but once allowed to stabalise it doesn't move unless knocked. I only need the laser to not move for one measurement run, as I'm not trying to align to the laser rather to get the errors between the laser and whatever i'm measuring to lie in a straight line. From my initial experiments the laser doesn't move at all over say a 10min session. The Dewalt laser I'm using is damped with a magnet, this probably helps. The laser doesn't even need to be self leveling, this just helps getting it setup.
So the process would be switch on the laser (this moves it a bit), wait for a few seconds for it to stabalise, take N measurements along a rail, switch the laser off, shim the rail, repeat. It doesn't matter if the laser moves between runs.
Cheers, JoeLast edited by devmonkey; 01-09-2019 at 04:08 PM.
The Following User Says Thank You to devmonkey For This Useful Post:
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
