06-11-2019 #11
Bare sensor, unless there is anti aliasing filter glued to silicon, but AFAIK it's DSLR's area.
Stripping further is not really an option, not usable as shadow camera as there are modular PCB's perpendicular to the sensor sticking above it's surface. Webcam incoming.
Cable is clamped, moving laptop around has no impact on measurements when camera is stationary.
Thinking about it makes no sense.
Both lasers are focusable, both are set to project same width/size line/dot at 8 meters and 20 cm.
They might be represented as
Laser diodes are not perfect, if one edge is brighter (double line above) average brightness will still be straight line
Pointer produces coupe stray beams right next to the main point, that could be source of the problem.
with line laser i have no idea.
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
