    Quote Originally Posted by davebaldwin View Post
    Let me elaborate.
    To make a rail straight you are changing one degree of freedom so by mounting your camera on a rail truck with the laser pointing parallel to the desired path (and obviously intersecting the camera). A simple measure of how far off the centre of the laser beam gives you the amount of displacement of the rail you need to make before the rail is in line with the laser.
    Traditionally, to make a surface planar (or two surfaces separated by a gap) you would use a known good plane - i.e. surface plate and a marking out fluid. Blue up the surfaces and use the surface place to rub the marking fluid off the high spots. This then identifies where you need to scrape to bring both surfaces into the same plane. The marking process is essentially in 3D as it extends along the width, length and heigh of the target surface.
    Now for the laser plane method. Mount the laser plane generator on the master rail. Set the plane generator up so it is casting a reference plane parallel to the master rail and not at some pitch or roll error. On the slave rail mount the camera on a truck facing the master rail. Now the offset given by the camera from the laser's centre is how much in heigh the slave rail need to be moved. This is one dimension that has been taken care off. Sliding the slave truck (and maybe the laser plane generator as well) along the rail allows you to sample the height difference along the rail. Second dimension taken care off.
    The thing I am missing is how the 3rd dimension is taken care off? What we have done is to set the hight of a line on the slave rail to be the same height as the reference plane where it intersects the focal plane of the camera but not that the whole slave rail is in the same plane as the master rail. Looking at it another way we haven't set the roll (looking down the rail) of the master and slave rails to be the same. Is this a second order effect and it unlikely to be outside the planar tolerance of the trucks across the rails?
    Maybe this is covered elsewhere in the thread - I have read the whole thread over the months it has been running, but not in one sitting - and I apologise for the repetition in that case.
    On a separate note instead of having a fixed laser and rotating (expensive and hard to get) prism why not just rotate the laser? For this application I would have though the advantages of rotating a small piece of glass over a bulkier laser are necessary.
    Dave.
    Hi Dave,
    I think you are conflating the rail itself with creating a planar surface to mount the rail. Imagine we are trying to create a surface plate from a an uneven slab of concrete say. You would mark out a grid of X-Y points on the slab, setup your laser plane and measure height error to the laser at each point. Take any 3 non-co-linear points (there is a method to pick the optimal 3 but it doesn't matter here), compute the equation of the virtual plane that intersects these 3 points, then correct all the other point error heights to this plane. Now shim or scrape as appropriate every point other than the 3 chosen, rinse and repeat until you are happy with the planar error.
    If this process was done using just two lines of points one under each rail centre then yes each rail would have a roll error (like setting up a perfectly planar razor blade under each rail and to them) but if you instead level a surface that the rail will sit on using this method (say level the entire 80mm steel beam in my case) then the roll error will be eliminated (sufficiently eliminated).
    Rotating a laser without a penta prism wont work as you cannot build a sufficiently well aligned laser mount, it will always cause the rotated laser to project a cone rather than a plane, this is the entire point of a penta prism, it is agnostic to variance in angle of incidence. Remember 1 arcsecond (1/3600 of a degree) will equate to ~5um of error at 1m. If your mount is say 100mm across this needs to be both machined and the laser somehow aligned to it all to within a tolerance of 0.5um, I reckon this is impossible.
    Cheers, Joe
  1. WANTED: K40 laser
    By dfox1787 in forum Items Wanted
    Last Post: 23-10-2018, 08:34 PM
  2. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  3. FOR SALE: K40 laser not working (laser fires)
    By calida in forum Items For Sale
    Last Post: 31-03-2015, 08:45 PM
  4. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
  5. help with cnc laser
    By swinds in forum Laser Machines & Building
    Last Post: 09-01-2012, 10:15 PM
