19-08-2019 #9
I'm very interested to look at your software on github. I'm no great programmer but have an unused Raspeberry Pi and a Pi camera which my brother -in-law sent me. I've been trying to work out what to do with them so this might be a possibility.This is exactly the sort of application he'd enjoy seeing it used for. It would be a large sensor block though with the Pi included as the camera attaches directly to it.
Part of my concern with working out an exact series of measurements is separating the possible sources of a given error and being able to align the machine in a systematic way. There's no point making the axis of the spindle exactly vertical until after you've ensured the axis along which the Z assembly moves is vertical and that can't be done until the Y rails and gantry mountings are set up and so on.
Some assumptions might be possible if your mechanical construction is very accurate but my machine is built using welded steel construction, a drill press and hand tools without access to a milling machine or other precision machining, so it's accuracy will only ever depend on being able to make measurements and correct errors with shims. I designed the whole thing with that requirement in mind but it's being able to make accurate measurements without spending more on a variety of gauges than on the machine itself that has made this thread so interesting. Like many hobbyists I have more spare time than spare money and there's great satisfaction in following Arthur Wellesley's maxim.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
