25-08-2019 #10
Kit,
You need java.exe on your PATH and setup another environment variable JAVA_HOME that points to the directory with the jdk in it. e.g. if java.exe is in c:\\java\jdkXXXX\bin\java.exe then JAVA_HOME must point to c:\\java\jdkXXXX
Anyway to help i've put up a build in a zip file here:
https://github.com/betzuka/laserleve...ilds/laser.zip
Download that, unzip it and double click on laser.bat
It still requires that you have java installed.
Cheers, Joe
The Following User Says Thank You to devmonkey For This Useful Post:
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
