29-08-2019 #11
Watching the thread with interest, but unfortunately its been many years since I studied optics, and I'm not massively useful at this point! But I whole-heartedly agree that you want to keep the guassian characteristic where possible, as its a nice structure to fit to. You could use the FWHM from a flat-top profile, but I'd trust the guassian fit better as the regression uses the entire curve, rather than just the penumbras.
Re. lenses; It all depends on the incoming beam width, the radius of the rod/lens, and the refractive index of the material being used; in general I'd guesstimate that given a beam focused to infinity, you're likely to get a wider output spread by using a full rod, but there are so many variables here to play with, i'd be tempted to just go with an off the shelf lens designed for the job which will also guarantee clarity of the beam to a certain extent.Last edited by AndyUK; 29-08-2019 at 02:32 PM.
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
